Help with new device in the zigbee2mqtt addon
HI guys,
Firstly i’m quite new to Home Assistant so still learning.
So i’ve setup the zigbee2mqtt and the mqqt addons and intergrated it and i added my first zigbee device which was a ikea motion sensor and that added fine and popped up in the MQTT intergration and is now working fine.
So i went to add my next motion sensor which added fine as well as a “Xiaomi Aqara human body movement and illuminance sensor” but this time it didn’t come through in the MQTT integration but it is showing the correct states within the Zigbee2mqtt web UI.
Nothings showing in the developers tools and entitties lists and see no mention in the logs, i’ve also restarted the server but still the same.
From what i’ve read i may need to manually add it but i can’t figure out how to do it any help would be appreciated.
I do not have any experience using that particular sensor. However there is a good page for info for that sensor, Here: https://www.zigbee2mqtt.io/devices/RTCGQ11LM.html
Also try to go through pairing process again. It may have missed an interview step.
Hope its of help.
Thanks for that link its really helpful, do they have a page for all devices ? i can’t see any links for devices on the main page.
I just forced deleted and re paired and it got added straight away.
See supported devices om the main page.
Thanks for that.
