Help with new garage template
Hi all, can someone please see why my new config is not working. I’m trying to move to the new template for my garage and gate. I use Sonoff SV for both, and monitor the state with a basic window/door sensor. Nothing too fancy, just a momentary on/off switch.
Old config:
cover:
    covers:
      garage_door:
        friendly_name: "Garage"
        value_template: "{{ states('binary_sensor.garage_door_window_door_is_open')|regex_replace('on','open')|regex_replace('off','closed') }}"
        open_cover:
          service_template: >
            {% if is_state('binary_sensor.garage_door_window_door_is_open', 'off') %}
              switch.turn_on
            {% endif %}
          entity_id: switch.sonoff_10008d36fa
        close_cover:
          service_template: >
            {% if is_state('binary_sensor.garage_door_window_door_is_open', 'on') %}
              switch.turn_on
            {% endif %}
        icon_template: >
            mdi:garage-open
          {% else %}
            mdi:garage
          {% endif %}
      gate:
        friendly_name: "Gate"
        value_template: "{{ states('binary_sensor.gate_sensor_window_door_is_open')|regex_replace('on','open')|regex_replace('off','closed') }}"
        open_cover:
          service_template: >
            {% if is_state('binary_sensor.gate_sensor_window_door_is_open', 'off') %}
              switch.turn_on
            {% endif %}
          entity_id: switch.sonoff_10008d36e9
        close_cover:
          service_template: >
            {% if is_state('binary_sensor.gate_sensor_window_door_is_open', 'on') %}
              switch.turn_on
            {% endif %}
        icon_template: >
            mdi:gate
          {% else %}
            mdi:gate
          {% endif %}
New config:
template:
  - cover:
      - name: Garage
        open_cover:
          service: >-
              switch.turn_on
            {% endif %}
        close_cover:
          service: >-
              switch.turn_on
            {% endif %}
        default_entity_id: cover.garage_door
        icon: >-
            mdi:garage-open
          {% else %}
            mdi:garage
          {% endif %}
        state: >-
          {{ states('binary_sensor.garage_door_window_door_is_open') | regex_replace('on','open') | regex_replace('off','closed') }}
      - name: Gate
        open_cover:
          service: >-
              switch.turn_on
            {% endif %}
        close_cover:
          service: >-
              switch.turn_on
            {% endif %}
        default_entity_id: cover.gate
        icon: >-
            mdi:gate
          {% else %}
            mdi:gate
          {% endif %}
        state: >-
          {{ states('binary_sensor.gate_sensor_window_door_is_open') | regex_replace('on','open') | regex_replace('off','closed') }}
Alot of that is outdated and can be optimized.
This goes in your configuration.yaml file.
template:
  - cover:
      - name: Garage
        open_cover:
          action: switch.turn_on
        close_cover:
        device_class: garage
        state: "{{ states('binary_sensor.garage_door_window_door_is_open') }}"
      - name: Gate
        open_cover:
        close_cover:
        device_class: gate
        state: "{{ states('binary_sensor.gate_sensor_window_door_is_open') }}"
Thank you. That works. The gate is still showing as unknown and not functional, but I think that’s because the sensor is not working. It used to function without the sensor, but didn’t show the state of the gate (open or close) I’ll put a new sensor on the gate, it’s a bit far, so a zigbee or zwave sensor link is usually weak.
