This may be a simpler approach. Note: I use:
Actionable Notifications Subflow for Android | node-red-contrib-home-assistant-websocket
[{"id":"6dc0247c.d7210c","type":"subflow","name":"Actionable Notification","info":"[Documentation](https://zachowj.github.io/node-red-contrib-home-assistant-websocket/cookbook/actionable-notifications-subflow-for-android.html)\n","category":"","in":[{"x":84,"y":80,"wires":[{"id":"9d85d137.fe487"}]}],"out":[{"x":1172,"y":128,"wires":[{"id":"974bd48d.c253e8","port":0}]},{"x":1172,"y":176,"wires":[{"id":"974bd48d.c253e8","port":1}]},{"x":1172,"y":224,"wires":[{"id":"974bd48d.c253e8","port":2}]},{"x":964,"y":240,"wires":[{"id":"5bc7345c.07b1cc","port":1}]}],"env":[{"name":"service","type":"str","value":"","ui":{"label":{"en-US":"Notify Service"},"type":"input","opts":{"types":["str"]}}},{"name":"title","type":"str","value":"","ui":{"label":{"en-US":"Title"},"type":"input","opts":{"types":["str"]}}},{"name":"message","type":"str","value":"","ui":{"label":{"en-US":"Message"},"type":"input","opts":{"types":["str"]}}},{"name":"action1Title","type":"str","value":"","ui":{"label":{"en-US":"Action 1 Title"},"type":"input","opts":{"types":["str"]}}},{"name":"action1Uri","type":"str","value":"","ui":{"label":{"en-US":"Action 1 URI (optional)"},"type":"input","opts":{"types":["str"]}}},{"name":"action2Title","type":"str","value":"","ui":{"label":{"en-US":"Action 2 Title"},"type":"input","opts":{"types":["str"]}}},{"name":"action2Uri","type":"str","value":"","ui":{"label":{"en-US":"Action 2 URI (optional)"},"type":"input","opts":{"types":["str"]}}},{"name":"action3Title","type":"str","value":"","ui":{"label":{"en-US":"Action 3 Title"},"type":"input","opts":{"types":["str"]}}},{"name":"action3Uri","type":"str","value":"","ui":{"label":{"en-US":"Action 3 URI (optional)"},"type":"input","opts":{"types":["str"]}}},{"name":"userInfo","type":"bool","value":"false","ui":{"label":{"en-US":"Populate User Information"},"type":"checkbox"}},{"name":"sticky","type":"bool","value":"false","ui":{"label":{"en-US":"Sticky"},"type":"checkbox"}},{"name":"group","type":"str","value":"None","ui":{"label":{"en-US":"Group"},"type":"select","opts":{"opts":[{"l":{"en-US":"None"},"v":""},{"l":{"en-US":"Cameras"},"v":"camera"},{"l":{"en-US":"Security"},"v":"security"},{"l":{"en-US":"Garage"},"v":"garage"},{"l":{"en-US":"Laundry Room"},"v":"laundry_room"}]}}},{"name":"color","type":"str","value":"","ui":{"label":{"en-US":"Color"},"type":"input","opts":{"types":["str"]}}},{"name":"timeout","type":"num","value":"","ui":{"label":{"en-US":"Timeout"},"type":"input","opts":{"types":["num"]}}},{"name":"icon","type":"str","value":"","ui":{"label":{"en-US":"Icon"},"type":"input","opts":{"types":["str"]}}}],"meta":{},"color":"#DDAA99","outputLabels":["Action 1","Action 2","Action 3","Cleared"],"status":{"x":244,"y":272,"wires":[{"id":"204dbcfc.144ae4","port":0}]}},{"id":"f9e57204.71076","type":"function","z":"6dc0247c.d7210c","name":"create service call","func":"const actions = [];\n[1,2,3].forEach(i => {\n const name = `action${i}`\n const id = flow.get(`${name}Id`);\n const title = env.get(`${name}Title`);\n const uri = env.get(`${name}Uri`);\n const action = !!uri.length ? 'URI' : title ? flow.get(`${name}Id`) : undefined;\n \n actions.push({\n action,\n title,\n uri\n });\n});\n\nmsg._originalPayload = msg.payload;\nflow.set('latestMessage', msg);\n\nconst services = env.get('service');\nif(!services) {\n node.status({\n text: 'no services defined',\n shape: 'ring',\n fill: 'red'\n });\n return; \n}\n\nservices.trim().split(/,\\s*/).forEach(service => {\n if(!service) return;\n \n msg.payload = {\n service,\n data: {\n title: env.get('title'),\n message: env.get('message'),\n data: {\n tag: flow.get('notificationTag'),\n actions,\n color: env.get(\"color\"),\n group: env.get(\"group\"),\n sticky: env.get(\"sticky\"),\n timeout: env.get(\"timeout\"),\n icon: env.get(\"icon\"),\n priority: \"high\",\n channel: \"alarms\"\n }\n }\n };\n node.send(msg);\n});\n\nnode.done();","outputs":1,"noerr":0,"initialize":"const randomId = () => Math.random().toString(36).replace(/[^a-z]+/g, '').substr(0, 5);\n\n[1,2,3].forEach(i => {\n flow.set(`action${i}Id`, `action${i}_${randomId()}`);\n})\n\n\nflow.set('notificationTag', `${env.get('title')}_${randomId()}`);","finalize":"","libs":[],"x":298,"y":80,"wires":[["368c9723.5876f8"]]},{"id":"974bd48d.c253e8","type":"switch","z":"6dc0247c.d7210c","name":"which action?","property":"eventData.event.action","propertyType":"msg","rules":[{"t":"eq","v":"action1Id","vt":"flow"},{"t":"eq","v":"action2Id","vt":"flow"},{"t":"eq","v":"action3Id","vt":"flow"}],"checkall":"true","repair":false,"outputs":3,"x":1024,"y":176,"wires":[[],[],[]]},{"id":"204dbcfc.144ae4","type":"status","z":"6dc0247c.d7210c","name":"","scope":["f9e57204.71076","5bc7345c.07b1cc","a622c92a.2d9898","368c9723.5876f8"],"x":124,"y":272,"wires":[[]]},{"id":"5bc7345c.07b1cc","type":"function","z":"6dc0247c.d7210c","name":"build message","func":"const latestMessage = flow.get('latestMessage');\nconst event = msg.payload.event;\n\nlatestMessage.eventData = msg.payload;\nlatestMessage.payload = latestMessage._originalPayload;\ndelete latestMessage._originalPayload;\n\nif(env.get('userInfo')) {\n const userData = msg.userData.find(u => u.id === msg.payload.context.user_id);\n latestMessage.userData = userData;\n}\n\nif(msg.event_type === 'mobile_app_notification_cleared') {\n node.status({\n text: `cleared at: ${getPrettyDate()}`,\n shape: 'dot',\n fill: 'blue'\n });\n \n return [null, latestMessage];\n}\n\nconst index = [1,2,3].find(i => event[`action_${i}_key`] === event.action);\nnode.status({\n text: `${event[`action_${index}_title`]} at: ${getPrettyDate()}`,\n shape: 'dot',\n fill: 'green'\n});\n\nreturn latestMessage;\n\n\nfunction getPrettyDate() {\n return new Date().toLocaleDateString('en-US', {\n month: 'short',\n day: 'numeric',\n hour12: false,\n hour: 'numeric',\n minute: 'numeric',\n });\n}","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":832,"y":176,"wires":[["974bd48d.c253e8"],[]]},{"id":"8d3bdc0c.37493","type":"switch","z":"6dc0247c.d7210c","name":"belongs here?","property":"payload.event.tag","propertyType":"msg","rules":[{"t":"eq","v":"notificationTag","vt":"flow"}],"checkall":"true","repair":false,"outputs":1,"x":432,"y":176,"wires":[["83ad2004.d04d"]]},{"id":"271e4479.b9249c","type":"ha-api","z":"6dc0247c.d7210c","name":"get user info","server":"","version":1,"debugenabled":false,"protocol":"websocket","method":"get","path":"","data":"{\"type\": \"config/auth/list\"}","dataType":"json","responseType":"json","outputProperties":[{"property":"userData","propertyType":"msg","value":"","valueType":"results"}],"x":822,"y":128,"wires":[["5bc7345c.07b1cc"]]},{"id":"3618f055.6909a","type":"server-events","z":"6dc0247c.d7210c","name":"mobile_app_notification_cleared","server":"","version":3,"exposeAsEntityConfig":"","eventType":"mobile_app_notification_cleared","waitForRunning":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"},{"property":"event_type","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"x":194,"y":224,"wires":[["8d3bdc0c.37493"]]},{"id":"83ad2004.d04d","type":"switch","z":"6dc0247c.d7210c","name":"fetch user info?","property":"userInfo","propertyType":"env","rules":[{"t":"true"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":624,"y":176,"wires":[["271e4479.b9249c"],["5bc7345c.07b1cc"]]},{"id":"9d85d137.fe487","type":"switch","z":"6dc0247c.d7210c","name":"","property":"clear_notification","propertyType":"msg","rules":[{"t":"null"},{"t":"nnull"}],"checkall":"true","repair":false,"outputs":2,"x":143,"y":80,"wires":[["f9e57204.71076"],["a622c92a.2d9898"]],"l":false},{"id":"a622c92a.2d9898","type":"function","z":"6dc0247c.d7210c","name":"create clear notification","func":"const services = env.get('service');\nif(!services) {\n node.status({\n text: 'no services defined',\n shape: 'ring',\n fill: 'red'\n });\n return; \n}\n\nservices.trim().split(/,\\s*/).forEach(service => {\n if(!service) return;\n \n msg.payload = {\n service,\n data: {\n message: \"clear_notification\",\n data: {\n tag: flow.get('notificationTag'),\n }\n }\n };\n node.send(msg);\n});\n\nnode.done();","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":318,"y":128,"wires":[["368c9723.5876f8"]]},{"id":"9bfe567c.3d10c8","type":"server-events","z":"6dc0247c.d7210c","name":"mobile_app_notification_action","server":"","version":3,"exposeAsEntityConfig":"","eventType":"mobile_app_notification_action","waitForRunning":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"},{"property":"event_type","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"x":194,"y":176,"wires":[["8d3bdc0c.37493"]]},{"id":"368c9723.5876f8","type":"api-call-service","z":"6dc0247c.d7210c","name":"","server":"","version":5,"debugenabled":false,"domain":"notify","service":"notify","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"json","mergeContext":"callServiceData","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":530,"y":100,"wires":[[]]},{"id":"919173f3b6568e0f","type":"bigtimer","z":"8b43de8505f17be7","outtopic":"","outpayload1":"on","outpayload2":"off","name":"Sunset-Sunrise","comment":"","lat":"","lon":"","starttime":"5004","endtime":"5004","starttime2":0,"endtime2":0,"startoff":"0","endoff":"0","startoff2":0,"endoff2":0,"offs":0,"outtext1":"","outtext2":"","timeout":1440,"sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":0,"month7":0,"day8":0,"month8":0,"day9":0,"month9":0,"day10":0,"month10":0,"day11":0,"month11":0,"day12":0,"month12":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xday7":0,"xmonth7":0,"xday8":0,"xmonth8":0,"xday9":0,"xmonth9":0,"xday10":0,"xmonth10":0,"xday11":0,"xmonth11":0,"xday12":0,"xmonth12":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":false,"atstart":false,"odd":false,"even":false,"x":620,"y":1000,"wires":[["479e4a5089231ba3"],[],[]]},{"id":"479e4a5089231ba3","type":"api-current-state","z":"8b43de8505f17be7","name":"Door 1 open?","server":"","version":3,"outputs":2,"halt_if":"Violated","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.elkm1_garage_oh_door_1","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"15","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":820,"y":1000,"wires":[["93094498664ec804"],[]]},{"id":"93094498664ec804","type":"subflow:6dc0247c.d7210c","z":"8b43de8505f17be7","name":"Manage Garage Door","env":[{"name":"service","value":"mobile_app_pixel_8","type":"str"},{"name":"title","value":"Garage Door","type":"str"},{"name":"message","value":"Garage Door is Open.<br>Do you want to close the door?","type":"str"},{"name":"action1Title","value":"Yes","type":"str"},{"name":"action2Title","value":"No","type":"str"},{"name":"group","value":"","type":"str"}],"x":1060,"y":1000,"wires":[["0b4d1337a31ae7ad"],["4ac099eab1b2f9d7"],[],[]]},{"id":"0b4d1337a31ae7ad","type":"api-call-service","z":"8b43de8505f17be7","name":"Close Garage Door","server":"","version":5,"debugenabled":false,"domain":"","service":"","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1290,"y":980,"wires":[[]]},{"id":"4ac099eab1b2f9d7","type":"delay","z":"8b43de8505f17be7","name":"Wait 30 Min","pauseType":"delay","timeout":"30","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1270,"y":1060,"wires":[["93094498664ec804"]]}]
