I’m trying to create a automation that will notify me when the tempurature for my fridge goes below a target tempurature.
Its an LG Fridge, which from its integration pulls in the target tempurature (IE programmed at the fridge itself from front panel or their preprietary app) as climate.refrigerator_fridge, and then shows the current temp temp as sensor.refrigerator_fridge_temp.
I have seen examples of how to have a trigger where you type the temp in manually into the automation, but I want it to pick this up from the entity from the fridge, that way its all dynamic. If I change it from the fridge, thats the new target.
So far I think the trigger should be this:
- platform: numeric_state
entity_id:
- sensor.refrigerator_fridge_temp
below: climate.refrigerator_fridge
But it gives me a an error:
Message malformed: expected float for dictionary value @ data[‘below’]
Any ideas?
I tried playing with stuff like replacing the below entry with:
below: {{ states(‘climate.refrigerator_fridge’)|float}}
but its not working, as I’m not sure quite how the float syntax needs to be… or if I’m even on the right track.
