Hi, I’m using one-button-dimmer node for my ikea remote to dim my lights
Before my ha crashed along with my node red flows backup, I used to able to get it working but I can’t recall exactly how I did it
Could anyone check what I’m missing?
When I hold the button and release, i can see the payload number increasing but no changes with my lights.
[{"id":"186ab4a895188684","type":"mqtt in","z":"36edc30d97569929","name":"","topic":"zigbee2mqtt/0x90fd9ffffe5a4bee/action","qos":"2","datatype":"auto","broker":"da8d15474208fac9","nl":false,"rap":true,"rh":0,"inputs":0,"x":210,"y":2640,"wires":[["e8e1da4977613f89"]]},{"id":"e8e1da4977613f89","type":"switch","z":"36edc30d97569929","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"toggle","vt":"str"},{"t":"eq","v":"brightness_up_click","vt":"str"},{"t":"eq","v":"brightness_up_hold","vt":"str"},{"t":"eq","v":"brightness_up_release","vt":"str"},{"t":"eq","v":"brightness_down_click","vt":"str"},{"t":"eq","v":"brightness_down_hold","vt":"str"},{"t":"eq","v":"brightness_down_release","vt":"str"},{"t":"eq","v":"arrow_right_click","vt":"str"},{"t":"eq","v":"arrow_right_hold","vt":"str"},{"t":"eq","v":"arrow_right_release","vt":"str"},{"t":"eq","v":"arrow_left_click","vt":"str"},{"t":"eq","v":"arrow_left_hold","vt":"str"},{"t":"eq","v":"arrow_left_release","vt":"str"}],"checkall":"true","repair":false,"outputs":13,"x":470,"y":2660,"wires":[["f20b44f713cca01e"],["a7f7de50e5a24590"],["be4c4c27a30829f9"],[],["16093a60404880bc"],["38287aef4026b1d7"],["38287aef4026b1d7"],["c430d97a3e36bf7d"],["d0c43705174f4c6d"],[],["1448ac6fdf80f88d"],[],[]]},{"id":"38287aef4026b1d7","type":"one-button-dimmer","z":"36edc30d97569929","name":"Dim Up","interval":200,"step":5,"minValue":"2","maxValue":100,"startCommand":"brightness_down_hold","stopCommand":"brightness_down_release","x":940,"y":2880,"wires":[["a84a8d0d8fc22b37","c68b8a732134dd79"]]},{"id":"a84a8d0d8fc22b37","type":"api-call-service","z":"36edc30d97569929","name":"Night Lamp","server":"f4149317.d3794","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.gu10_bulb4"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1130,"y":2880,"wires":[[]]},{"id":"c68b8a732134dd79","type":"debug","z":"36edc30d97569929","name":"","active":true,"tosidebar":true,"console":true,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1160,"y":2820,"wires":[]},{"id":"da8d15474208fac9","type":"mqtt-broker","name":"MQTT hass","broker":"192.168.1.40","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"f4149317.d3794","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
