Hi could I ask for some help with a PCB design, I am just after a second look and opinion to see if I have missed anything or anything is incorrect.
It is 10x relays and a LilyGo T-Call, with a INA219 and GPS breakout headers.
Parts List:
1x LilyGo T-Call
8x Hongfa HF46F-005-HS1 Relays
2x Hongafa HF46F-012-HS1 Relays
1x INA219 board
Pololu D24V50F5 Regulator
With the 8 5v relays, the are triggered via the T-Call and provide a NO going closed contact.
With the 2 12v Relays, they are triggered via external 12v source and provide a NO going CLOSED contact to trigger a GPIO as INPUT on the T-Call.
I want to get it as close to WORKING as possible for first print. I dont know a huge amount about this stuff and am sure some stuff is wrong. Would appreciate any feedback.
Your 12V relays are wired backwards it seems. Coil gets pulled high to 3V3 which will do nothing. Contacts go to gnd and the 12V signal. Since the relay is NO nothing will happen.
lol okay well at that point you did right by coming here I would not use the board as fiver is full of people using chat gpt to do things. Your better off trial and error with a breadboard and design and print your own pcb you’d gain a skill
