Help with Petrol REST sensor
Ciao,
I’m trying to create a REST sensor to get petrol price from a specific petrol station. The CURL request is as follows:
curl --request GET "https://sedeaplicaciones.minetur.gob.es/ServiciosRESTCarburantes/PreciosCarburantes/EstacionesTerrestres/FiltroProvincia/28" | jq -r '.ListaEESSPrecio[] | select(.IDEESS=="4654") | ."Precio Gasolina 95 E5"'
I’ve tried the following config without success:
  - platform: rest
    resource: https://sedeaplicaciones.minetur.gob.es/ServiciosRESTCarburantes/PreciosCarburantes/EstacionesTerrestres/FiltroProvincia/28
    method: GET
    scan_interval: 86400
    json_attributes_path: "$.ListaEESSPrecio"
    value_template: >
      {% set items = value_json | selectattr('IDEESS','eq','4654') | list | first %}
      {{ items['Precio Gasolina 95 E5'] }}
Can anyone guess what I’m doing wrong?
Thanks!!
Can you please format your post correctly.
Done, sorry!
json_attributes_path has no influence on value_template.
You need something like:
  - platform: rest
    method: GET
    value_template: >
      {% set items = value_json['ListaEESSPrecio'] | selectattr('IDEESS','eq','4654') | list | first %}
EDIT: you can “simplify” with
value_template: "value_json['ListaEESSPrecio'] | selectattr('IDEESS','eq','4654') | map(attribute='Precio Gasolina 95 E5') | list | first"
That was the issue. Thanks man!!
