Help with PIR sensor to activate light
I have a Wemos D1 Mini with a motion sensor connected to it. I would like to add a LED of 5v to it so if the montion sensor detects movement the led will stay ON for 60 seconds.
For now I have this:
binary_sensor:
  - platform: gpio
    pin: GPIO12
    device_class: motion
Is it possible to use the same Wemos to power the 5v led?
Where do I need to connect the LED and what do I have to add to the code?
Tried this but not working…
switch:
  - platform: gpio
    pin: GPIO14
binary_sensor:
  - platform: gpio
    pin: GPIO12
    on_press:
      then:
        - switch.turn_on:
    filters:
     delayed_on: 60s
You set up a led per this Binary Light — ESPHome
