I have an energy sensor that shows real time power usage, only problem is it drops to 0 once in a while. Im trying to have it display the last value if the sensor is at 0. I have this which is working but I have solar as well which means I will get a negative value to, and when I get a negative value it shows unavailable.
this is what I have
- sensor:
- name: sensor.torrance_street_123_1min_2
unit_of_measurement: "W"
unique_id: Current Watt Use
state: >-
{% set e = states('sensor.torrance_street_123_1min') %}
{% if e | is_number and e | int(0) > 0 %}
{{ e | int(0) }}
{% else %}
{{ this.state }}
{% endif %}
