I have an entity sensor.barns_pv_power (unit of measurement: w ) that I would like to send to my MQTT broker (on a separate RPi), which I will then send to my Node-RED app which is on yet another separate RPi. I understand how those two RPi’s work together.
I have installed the MQTT integration in HA, but I don’t know how to configure it.
Presumably I create a topic name (say “barns_pv”), but what would I put in the Payload field?
Thank you so much @123 - that works! A quick follow up question though; using an app called MQTT Explorer, I see that the topic comes through as barns_pv, but I would like it to be a subset of emon. What would be the correct syntax for this? Changing the topic to topic: emon.barns_pv doesn’t work, nor does `topic: emon/barns_pv’ .
