After update Home Assistant 2022.8.2,the integrations DaikinDTA116A621 Invalid。
The errors information:
Error during setup of component daikin_dta116a621
File “/usr/src/homeassistant/homeassistant/setup.py”, line 235, in _async_setup_component
result = await task
File “/config/custom_components/daikin_dta116a621/init.py”, line 64, in async_setup
adapter : DaikinAPI = await hass.async_add_executor_job(create_adapter, conf_adapter_host, conf_adapter_port, conf_adapter_slave)
File “/usr/local/lib/python3.10/concurrent/futures/thread.py”, line 58, in run
File “/config/custom_components/daikin_dta116a621/init.py”, line 75, in create_adapter
api = DaikinAPI(host, port, slave)
File “/usr/local/lib/python3.10/site-packages/pydta116a621/init.py”, line 20, in init
self._areas.update_all()
File “/usr/local/lib/python3.10/site-packages/pydta116a621/register_area.py”, line 58, in update_all
proxy.update_all()
File “/usr/local/lib/python3.10/site-packages/pydta116a621/proxy.py”, line 46, in update_all
self.update_cells(self._base_address, self._cells_count)
File “/usr/local/lib/python3.10/site-packages/pydta116a621/proxy.py”, line 42, in update_cells
cells = self._modbus_client.read_cells(self.register_type, address, this_turn_cells_count)
File “/usr/local/lib/python3.10/site-packages/pydta116a621/modbus_client.py”, line 30, in read_cells
cells = self._read_input_cells(address, count)
File “/usr/local/lib/python3.10/site-packages/pydta116a621/modbus_client.py”, line 21, in _read_input_cells
return result.registers
AttributeError: ‘ModbusIOException’ object has no attribute ‘registers’
The pydta116a621 is changed?Please help me
