I have also recently had this error, not sure what the issue is here is my log can anyone help me please?
This error originated from a custom integration.
Logger: homeassistant.setup
Source: custom_components/pyscript/init.py:27
Integration: pyscript (documentation, issues)
First occurred: 5:30:43 AM (1 occurrences)
Last logged: 5:30:43 AM
Setup failed for custom integration pyscript: Unable to import component: cannot import name ‘Event’ from ‘homeassistant.helpers.event’ (/usr/src/homeassistant/homeassistant/helpers/event.py)
File “/usr/src/homeassistant/homeassistant/setup.py”, line 215, in _async_setup_component
component = integration.get_component()
File “/usr/src/homeassistant/homeassistant/loader.py”, line 813, in get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File “/usr/local/lib/python3.11/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1204, in _gcd_import
File “”, line 1176, in _find_and_load
File “”, line 1147, in _find_and_load_unlocked
File “”, line 690, in _load_unlocked
File “”, line 940, in exec_module
File “”, line 241, in _call_with_frames_removed
File “/config/custom_components/pyscript/init.py”, line 27, in
from homeassistant.helpers.event import Event as HAEvent
ImportError: cannot import name ‘Event’ from ‘homeassistant.helpers.event’ (/usr/src/homeassistant/homeassistant/helpers/event.py)
