Help with rainy day notification
Hey,
so if a door/window is open (samsung smartthing multisensor) and it starts to rain… notify me and tell me which item needs to be closed.
where am i going wrong?
this doesnt fire…
- alias: Rainy Day Door and Window Alert
    platform: state
    entity_id:
      - binary_sensor.bar_door_sensor_contact
      - binary_sensor.en_suite_window_sensor_contact
      - binary_sensor.multipurpose_sensor_downstairs_bathroom_window_contact
    to: "on"
  condition:
  - condition: state
    entity_id: sensor.dark_sky_icon
    state: 'rain'
    service: persistent_notification.create
    data_template:
      message: '{{ trigger.from_state.attributes.friendly_name }} is open and its raining!'
      title: Its raining!
    service: notify.notify
    data_template:
      title: Its raining!
First, do you want it to run the actions when a door or window is opened, or when it starts to rain? If the latter then you have the triggers and conditions reversed.
Second, are you sure sensor.dark_sky_icon is exactly ‘rain’ when it’s raining? Might it have other values when it’s raining?
Third, your actions are not entered as a proper list. You forgot the dashes.
Hey,
thanks for the reply.
first question:
i think both?
i would want to alert if it starts to rain and a door is open
but also, if its already raining and a door then opens?
i did have it reversed at first, however i then couldnt work out how to use a “conditon” value in my notify, so i knew which door opened, if it started to rain.
second.
yes, i checked and that value does go to “rain”
icon optional
A machine-readable text summary of this data point, suitable for selecting an icon for display. If defined, this property will have one of the following values: clear-day, clear-night, rain, snow, sleet, wind, fog, cloudy, partly-cloudy-day, or partly-cloudy-night. (Developers should ensure that a sensible default is defined, as additional values, such as hail, thunderstorm, or tornado , may be defined in the future.)
third,
sorry, where should i add the dashes?
First define a group with the three sensors. This will make things a little easier later.
group:
  doors_windows:
    name: Doors and Windows
    entities:
    - platform: state
      entity_id:
      to: 'on'
    - platform: state
      to: 'rain'
  condition:
    - condition: state
      entity_id: group.doors_windows
      state: 'on'
    - condition: state
      state: 'rain'
    - service: persistent_notification.create
      data_template:
        message: >
          {% set open = states.binary_sensor
             |selectattr('entity_id','in',state_attr('group.doors_windows','entity_id'))
             |selectattr('state','eq','on')
             |map(attribute='name')|list %}
          {{ list|join(', ') }} {{ 'are' if list|length > 1 else 'is' }} open and it's raining!
        title: "It's raining!"
    - service: notify.notify
      data_template:
        message: >
wow, thanks a lot!!
so its firing as expected now - awesome,
however the template to work out the door/window doesnt open.
its just “empty” in the notification.
so it reads “is open and it’s raining!”
this works:
{% set open =
     |selectattr
     |selectattr
           ('state','eq','on')
     |map
         (attribute='name')
|list %}
   {{ open|join(', ') }} {{ 'are' if open|length > 1 else 'is' }} open and it's raining!
D’oh! My bad. This was the problem:
it should have been:
as you discovered.
no worries at all - thanks so much for the help!!
so i assume this will trigger on both:
  • any door thats open WHEN it starts to rain
  • any door that opens, if is ALREADY raining
Yes, that’s the idea. Let me know if you have any more issues with it.
Thanks for all the help!!
Out of interest, do you just “know” how to code this all or is there a better way to play around and test stuff ?
I used to do a load of SQL and using SQLSquirrel really helped me to learn and get stuff done
Well, I’ve been a programmer for over 40 years, so that helps a little. :wink:
Mainly it’s reading the docs, following posts on this forum, and playing around with HA for about a year or so trying different things, and reading the HA code, too, as needed. The Template editor is a HUGE help. Also I’m never far from a command line where I can invoke a Python interpreter to try some things, too.
