Help with re-adding ZWAVE switches after I removed them
Dear forum members
I would appreciate your help with re-adding 2 Fibaro switches back to my system:
Configuration:
rpi 3 + USB ZWAVE stick (AEON Labs ZW090 Z-Stick Gen5 EU )
The only zwave nodes that I have are the controller (ZWAVE stick) and the 2 switches.
node001 - Zwave stick
node003 and node 005 are the switches
Why I removed the nodes:
In the past 2 weeks I have seen the nodes going dead from time to time. They have been operating successfully for the past year or so, so I decided to remove them and add them back.
How did I remove the nodes
In the GUI I hit the remove node button
How did I add them back ?
By hitting the “Add node secure” and then turned on and off the physical switch few times.
This is the zwave log file:
at 8:44 I started the ZWAVE network. Surprisingly I see in the log references to Node045, Node57, Node215, Node172, Node032. Not sure what are these nodes. I don’t have them… I don’t think any of my neighbors have ZWAVE.
At 8:46 I did a network heal, that ended up with “Notification: ControllerCommand - Failed”
At 08:58 I see Node003 and Node005 start chatting. Nevertheless I don’t see their entities in the HA GUI :frowning:
Any ideas ? thanks !
2020-01-12 08:44:13.195 Always, OpenZwave Version 1.4.3452 Starting Up
2020-01-12 08:44:41.524 Info, Setting Up Provided Network Key for Secure Communications
2020-01-12 08:44:41.525 Info, mgr,     Added driver for controller /dev/ttyACM0
2020-01-12 08:44:41.530 Info,   Opening controller /dev/ttyACM0
2020-01-12 08:44:41.530 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2020-01-12 08:44:41.531 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2020-01-12 08:44:41.532 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-01-12 08:44:41.532 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-01-12 08:44:41.532 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-01-12 08:44:41.532 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-01-12 08:44:41.532 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-01-12 08:44:41.532 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-01-12 08:44:41.535 Detail, contrlr,   Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x35, 0x34, 0x00, 0x01, 0x93
2020-01-12 08:44:41.535 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2020-01-12 08:44:41.535 Info, contrlr,     Static Controller library, version Z-Wave 4.54
2020-01-12 08:44:41.535 Detail, Node045,   Expected reply was received
2020-01-12 08:44:41.535 Detail, Node045,   Message transaction complete
2020-01-12 08:44:41.535 Detail, contrlr, Removing current message
2020-01-12 08:44:41.535 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-01-12 08:44:41.543 Detail, contrlr,   Received: 0x01, 0x08, 0x01, 0x20, 0xc4, 0x39, 0x75, 0x91, 0x01, 0xce
2020-01-12 08:44:41.543 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xc4397591.  Our node ID = 1
2020-01-12 08:44:41.543 Detail, Node057,   Expected reply was received
2020-01-12 08:44:41.543 Detail, Node057,   Message transaction complete
2020-01-12 08:44:41.543 Detail, contrlr, Removing current message
2020-01-12 08:44:41.544 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-01-12 08:44:41.546 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x05, 0x28, 0xd7
2020-01-12 08:44:41.546 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2020-01-12 08:44:41.546 Info, contrlr,     There is no SUC ID Server (SIS) in this network.
2020-01-12 08:44:41.546 Info, contrlr,     The PC controller is a primary controller.
2020-01-12 08:44:41.546 Detail, Node215,   Expected reply was received
2020-01-12 08:44:41.546 Detail, Node215,   Message transaction complete
2020-01-12 08:44:41.546 Detail, contrlr, Removing current message
2020-01-12 08:44:41.546 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-01-12 08:44:41.555 Detail, contrlr,   Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x01, 0x00, 0x86, 0x00, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfa
2020-01-12 08:44:41.555 Info, contrlr,  Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2020-01-12 08:44:41.555 Info, contrlr,     Serial API Version:   1.1
2020-01-12 08:44:41.555 Info, contrlr,     Manufacturer ID:      0x0086
2020-01-12 08:44:41.555 Info, contrlr,     Product Type:         0x0001
2020-01-12 08:44:41.555 Info, contrlr,     Product ID:           0x005a
2020-01-12 08:44:41.555 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-01-12 08:44:41.555 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-01-12 08:44:41.555 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-01-12 08:44:41.556 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-01-12 08:44:41.556 Detail, Node001,   Expected reply was received
2020-01-12 08:44:41.556 Detail, Node001,   Message transaction complete
2020-01-12 08:44:41.556 Detail, contrlr, Removing current message
2020-01-12 08:44:41.556 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-01-12 08:44:41.558 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2020-01-12 08:44:41.558 Info, contrlr, Received reply to GET_SUC_NODE_ID.  Node ID = 0
2020-01-12 08:44:41.558 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2020-01-12 08:44:41.558 Detail, Node172,   Expected reply was received
2020-01-12 08:44:41.558 Detail, Node172,   Message transaction complete
2020-01-12 08:44:41.559 Detail,
2020-01-12 08:44:41.559 Detail, contrlr, Removing current message
2020-01-12 08:44:41.559 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-01-12 08:44:41.615 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0xd7, 0xc2, 0x72, 0x68, 0x94, 0x7c, 0x63, 0x78, 0xc2, 0xb7, 0x91, 0x2c, 0x08, 0x44, 0x4d, 0x2f, 0xd9, 0xbd, 0x10, 0xff, 0x46, 0x68, 0xdc, 0xa1, 0xc6, 0x77, 0x6b, 0x2c, 0x3d, 0x77, 0x68, 0xcb, 0x3b
2020-01-12 08:44:41.615 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2020-01-12 08:44:41.615 Detail, Node032,   Expected reply was received
2020-01-12 08:44:41.615 Detail, Node032,   Message transaction complete
2020-01-12 08:44:41.615 Detail, contrlr, Removing current message
2020-01-12 08:44:41.615 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-01-12 08:44:41.719 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc5
2020-01-12 08:44:41.720 Info, mgr,     Driver with Home ID of 0xc4397591 is now ready.
2020-01-12 08:44:41.720 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2020-01-12 08:44:41.720 Info, contrlr,     Node 001 - Known
2020-01-12 08:44:41.720 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2020-01-12 08:44:41.720 Detail, Node001, QueryStage_CacheLoad
2020-01-12 08:44:41.720 Info, Node001, Node Identity Codes: 0086:0001:005a
2020-01-12 08:44:41.720 Detail, Node001, QueryStage_Associations
2020-01-12 08:44:41.720 Detail, Node001, QueryStage_Neighbors
2020-01-12 08:44:41.720 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2020-01-12 08:44:41.721 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-01-12 08:44:41.721 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2020-01-12 08:44:41.721 Detail,   Expected reply was received
2020-01-12 08:44:41.721 Detail,   Message transaction complete
2020-01-12 08:44:41.721 Detail, contrlr, Removing current message
2020-01-12 08:44:41.721 Detail, Node001, Notification: DriverReady
2020-01-12 08:44:41.724 Detail, Node001, Notification: NodeAdded
2020-01-12 08:44:41.728 Detail, Node001, Notification: NodeProtocolInfo
2020-01-12 08:44:41.729 Detail, Node001, Notification: EssentialNodeQueriesComplete
2020-01-12 08:44:41.734 Detail, Node001, Notification: ValueAdded
2020-01-12 08:44:41.738 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2020-01-12 08:44:41.741 Detail, Node001, Notification: NodeNaming
2020-01-12 08:44:41.743 Detail,
2020-01-12 08:44:41.744 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-01-12 08:44:41.746 Detail, contrlr,   Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2020-01-12 08:44:41.746 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2020-01-12 08:44:41.746 Detail, Node015,   Expected reply was received
2020-01-12 08:44:41.746 Detail, Node015,   Message transaction complete
2020-01-12 08:44:41.746 Detail, contrlr, Removing current message
2020-01-12 08:44:41.747 Detail,
2020-01-12 08:44:41.747 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-01-12 08:44:41.748 Detail, contrlr, Removing current message
2020-01-12 08:44:41.749 Detail,
2020-01-12 08:44:41.749 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-01-12 08:44:41.753 Detail, Node001,   Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5e
2020-01-12 08:44:41.753 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-01-12 08:44:41.753 Info, Node001,     Neighbors of this node are:
2020-01-12 08:44:41.753 Info, Node001,  (none reported)
2020-01-12 08:44:41.753 Detail,   Expected reply was received
2020-01-12 08:44:41.753 Detail,   Message transaction complete
2020-01-12 08:44:41.754 Detail,
2020-01-12 08:44:41.754 Detail, Node001, Removing current message
2020-01-12 08:44:41.754 Detail, Node001, Query Stage Complete (Neighbors)
2020-01-12 08:44:41.754 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2020-01-12 08:44:41.754 Detail, Node001, QueryStage_Session
2020-01-12 08:44:41.754 Detail, Node001, QueryStage_Dynamic
2020-01-12 08:44:41.754 Detail, Node001, QueryStage_Configuration
2020-01-12 08:44:41.754 Detail, Node001, QueryStage_Complete
2020-01-12 08:44:41.754 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2020-01-12 08:44:41.754 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2020-01-12 08:44:41.754 Info,          Node query processing complete.
2020-01-12 08:44:41.754 Detail, Node001, Notification: NodeQueriesComplete
2020-01-12 08:44:41.756 Detail, contrlr, Notification: AllNodesQueried
2020-01-12 08:46:36.371 Detail, Node001, Queuing (Controller) Request Node Neighbor Update
2020-01-12 08:46:36.371 Info, Requesting Neighbor Update for node 1
2020-01-12 08:46:36.371 Detail, Node001, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x0a, 0xb9
2020-01-12 08:46:36.372 Detail, Notification: ControllerCommand - Starting
2020-01-12 08:46:36.375 Detail,
2020-01-12 08:46:36.375 Info, Node001, Sending (Command) message (Callback ID=0x0a, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x0a, 0xb9
2020-01-12 08:46:36.397 Detail, Node001,   Received: 0x01, 0x05, 0x00, 0x48, 0x0a, 0x23, 0x9b
2020-01-12 08:46:36.397 Warning, Node001, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-01-12 08:46:36.397 Detail, Node035,   Expected callbackId was received
2020-01-12 08:46:36.397 Detail, Node035,   Expected reply was received
2020-01-12 08:46:36.397 Detail, Node035,   Message transaction complete
2020-01-12 08:46:36.398 Detail, Node001, Removing current message
2020-01-12 08:46:36.398 Detail, Notification: ControllerCommand - Failed
2020-01-12 08:58:23.501 Detail, Node005,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x05, 0x0e, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x34, 0x49, 0x00, 0x00, 0xa1
2020-01-12 08:58:23.502 Detail,
2020-01-12 08:58:23.575 Detail, Node005,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x05, 0x0e, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x21, 0x43, 0x00, 0x00, 0xbd
2020-01-12 08:58:23.576 Detail,
2020-01-12 08:58:23.676 Detail, Node003,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x04, 0xad, 0x00, 0x00, 0x73
2020-01-12 08:58:23.749 Detail, Node003,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x12, 0x23, 0x00, 0x00, 0xe8
2020-01-12 09:16:23.681 Detail, Node003,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x03, 0x0c, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xa8
2020-01-12 09:22:26.508 Detail, Node005,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x05, 0x0c, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xad
2020-01-12 09:32:03.512 Detail, Node005,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x05, 0x0c, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xae
2020-01-12 09:32:36.687 Detail, Node003,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x03, 0x0c, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xab
2020-01-12 09:58:23.505 Detail, Node005,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x05, 0x0e, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x34, 0x49, 0x00, 0x00, 0xa1
2020-01-12 09:58:23.578 Detail, Node005,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x05, 0x0e, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x21, 0x43, 0x00, 0x00, 0xbd
2020-01-12 09:58:23.680 Detail, Node003,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x04, 0xad, 0x00, 0x00, 0x73
2020-01-12 09:58:23.754 Detail, Node003,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x12, 0x23, 0x00, 0x00, 0xe8
2020-01-12 10:16:23.682 Detail, Node003,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x03, 0x0c, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xa8
2020-01-12 10:22:26.509 Detail, Node005,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x05, 0x0c, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xad
2020-01-12 10:32:03.511 Detail, Node005,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x05, 0x0c, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xae
2020-01-12 10:32:03.512 Detail,
2020-01-12 10:32:36.687 Detail, Node003,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x03, 0x0c, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xab
2020-01-12 10:32:36.688 Detail,
2020-01-12 10:58:23.520 Detail, Node005,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x05, 0x0e, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x34, 0x49, 0x00, 0x00, 0xa1
2020-01-12 10:58:23.521 Detail,
2020-01-12 10:58:23.594 Detail, Node005,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x05, 0x0e, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x21, 0x43, 0x00, 0x00, 0xbd
2020-01-12 10:58:23.595 Detail,
2020-01-12 10:58:23.696 Detail, Node003,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x04, 0xad, 0x00, 0x00, 0x73
2020-01-12 10:58:23.697 Detail,
2020-01-12 10:58:23.770 Detail, Node003,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x12, 0x23, 0x00, 0x00, 0xe8
2020-01-12 10:58:23.771 Detail,
2020-01-12 11:16:23.699 Detail, Node003,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x03, 0x0c, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xa8
2020-01-12 11:16:23.700 Detail,
2020-01-12 11:22:26.524 Detail, Node005,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x05, 0x0c, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xad
2020-01-12 11:22:26.525 Detail,
2020-01-12 11:32:03.527 Detail, Node005,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x05, 0x0c, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xae
2020-01-12 11:32:36.704 Detail, Node003,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x03, 0x0c, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xab
2020-01-12 11:58:23.535 Detail, Node005,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x05, 0x0e, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x34, 0x49, 0x00, 0x00, 0xa1
2020-01-12 11:58:23.536 Detail,
2020-01-12 11:58:23.609 Detail, Node005,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x05, 0x0e, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x21, 0x43, 0x00, 0x00, 0xbd
2020-01-12 11:58:23.712 Detail, Node003,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x04, 0xad, 0x00, 0x00, 0x73
2020-01-12 11:58:23.786 Detail, Node003,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x12, 0x23, 0x00, 0x00, 0xe8
2020-01-12 12:16:23.714 Detail, Node003,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x03, 0x0c, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xa8
2020-01-12 12:16:23.717 Detail,
2020-01-12 12:22:26.538 Detail, Node005,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x05, 0x0c, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xad
2020-01-12 12:22:26.541 Detail,
2020-01-12 12:32:03.541 Detail, Node005,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x05, 0x0c, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xae
2020-01-12 12:32:03.542 Detail,
2020-01-12 12:32:36.719 Detail, Node003,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x03, 0x0c, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xab
2020-01-12 12:32:36.720 Detail,
2020-01-12 12:58:23.552 Detail, Node005,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x05, 0x0e, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x34, 0x49, 0x00, 0x00, 0xa1
2020-01-12 12:58:23.625 Detail, Node005,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x05, 0x0e, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x21, 0x43, 0x00, 0x00, 0xbd
2020-01-12 12:58:23.730 Detail, Node003,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x04, 0xad, 0x00, 0x00, 0x73
2020-01-12 12:58:23.804 Detail, Node003,   Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x60, 0x0d, 0x02, 0x01, 0x32, 0x02, 0x21, 0x44, 0x00, 0x00, 0x12, 0x23, 0x00, 0x00, 0xe8
2020-01-12 13:16:23.732 Detail, Node003,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x03, 0x0c, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0xa8
2020-01-12 13:16:23.733 Detail,
When you removed the node did you also go to the device and execute it’s Exclusion sequence?
Removing it from the controller but not having the device execute the Exclude process can cause issues joining networks.
Thank you @Doranagun !
This explains why I see the old nodes “chatting”.
At the end I did physically removed the nodes, although I had trouble returning them back to the system.
Had to shut down mains, and press S1 for few seconds when turning mains back on. Only then could I re-add them. At last all works well now.
