Hi Guys,
I’m sure someone here can help me, I have just setup a mini weather station using the following ESP board http://www.switchdoc.com/weatherplus/
The software running in the board allows rest calls as can be seen here http://www.switchdoc.com/2016/06/ourweather-rest-interface-interface-raspberry-pi/
So I can make a rest call such as https://192.168.1.118/IndoorTemperature which is display the temp from the boad in my browser in json format as below
{"IndoorTemperatur
e": 27.47, "id":
"1", "name":
"OurWeather",
"connected": true}
I’m now wondering how to get this information into hassio? I had assumed that I would use the aRest Intergration, but so far I’ve been unable to make this work. https://www.home-assistant.io/integrations/rest/
I’m sure its really simple, but I’m struggling, I’d really appreciate if someone could point me in the right direction? Do I need a value template??
