I have an enigma2 decoder and I’m trying to add a sensor to see what channel TV’s are streaming.
The TV’s will be identified by the IP address which I have statically set
192.168.33.61 = Bedroom TV
192.168.33.243 = Lounge TV
192.168.33.244 = Office TV
As you can see from the below example, 192.168.33.244 has no entry because its currently off and not streaming.
"streams": [
"eventname": "Storage Wars",
"ip": "192.168.33.61",
"ref": "1:0:19:4CB:A:A4:3200000:0:0:0:",
"name": "Prime",
"type": "S"
"eventname": "",
"ip": "192.168.33.243",
"ref": "1:0:19:4AA:7:A1:3200000:0:0:0:",
"name": "Movies Family",
"type": "S"
I’m trying to use the rest sensor as follows, but not sure how to use the value template to search the json for the IP and then output the relevant channel name
- platform: rest
resource: http://192.168.33.3/api/about
value_template: "{{ value_json.[0].name }}"
You can use “selectattr” to filter the array to the ones with the IP you’re after:
{{ (value_json.streams
| selectattr('ip', 'eq', '192.168.33.243')
| first).name }}
Wow you are a legend, this worked in the developer template, but can’t get it to load in configuration
rest:
- authentication: basic
username: "user"
password: "pass"
scan_interval: 60
- name: "Master Bedroom Stream Channel"
value_template: {{ (value_json.info.streams | selectattr('ip', 'eq', '192.168.33.243') | first).name }}
- name: "Barry Laptop Stream Channel"
P.s. for anyone (including myself in the future) needing to test this in the dev tools template
{% set value_json = {
"info": {
"streams": [
"eventname": "The Simpsons",
"ref": "1:0:1:40C:16:2F:3200000:0:0:0:",
"name": "TVNZ 2",
"type": "S"
"eventname": "The Chase",
"ref": "1:0:1:40B:16:2F:3200000:0:0:0:",
"name": "TVNZ 1",
"type": "S"
"textinputsupport": false,
"chipset": "bcm7252s",
"model": "UHD QUAD 4K",
"friendlychipsettext": "Broadcom 7252s"
| first).name }}
The “value_template” needs to be a string, so either surround it in double-quotes, or put it on the next line like this:
value_template: >-
Thanks, fixed one issue came up with another
The system cannot restart because the configuration is not valid: Invalid config for [rest]: [value_template] is an invalid option for [rest]. Check: rest->rest->0->value_template. (See /config/configuration.yaml, line 29).
Does this mean I cannot use rest and do it in a single endpoint hit?
There are two REST sensors (this and this). You’re using the latter, which doesn’t have great documentation and I haven’t used it, so I’m not sure it uses “value_json”. Having said, your problem is probably identation - “value_template” should come under “name”, but because it’s below the “-”, it’s actually under “sensor”. Try changing to:
- name: blahblah
value_template: >-
your template
I’ve gone to individual sensors for now which is working; just means I have to make multiple calls to the same endpoint. Tried what you said but looks like it works differently and it doesn’t seem possible to do what I want
- platform: rest
username: "user"
password: "pass"
value_template: >-
method: GET
timeout: 10
- platform: rest
name: "Bedroom TV Stream Channel"
username: "user"
password: "pass"
value_template: >-
{{ (value_json.info.streams | selectattr('ip', 'eq', '192.168.33.61') | first).name }}
method: GET
timeout: 10
You were spot on with indent, found example here How to get multiple sensors for 1 rest call? - #6 by stanekl
Thanks for all your help!
Final config as follows for others:
rest:
username: "user"
password: "pass"
scan_interval: 60
- name: "Bedroom TV Stream Channel"
value_template: "{{ (value_json.info.streams | selectattr('ip', 'eq', '192.168.33.61') | first).name }}"
value_template: "{{ (value_json.info.streams | selectattr('ip', 'eq', '192.168.33.243') | first).name }}"
