i have a rgb controller running tasmota. i get the following message via MQTT (formatted):
stat/rgbled1/RESULT = {"POWER":"ON",
"Dimmer":67,
"Color":"93,171,73",
"HSBColor":"108,57,67",
"Channel":[36,67,29]}
Can somebody help me get the configuration entry right? I tried it with json template and other template, but at most i got parts of it working (e.g. on and off, but not the color or brightness).
- platform: mqtt
command_topic: "cmnd/rgbled1/power"
state_topic: "stat/rgbled1/POWER"
rgb_state_topic: "stat/rgbled1/color"
rgb_command_topic: "cmnd/rgbled1/color"
brightness_state_topic: "stat/rgbled1/DIMMER"
brightness_command_topic: "cmnd/rgbled1/dimmer"
retain: false
payload_available: "Online"
payload_not_available: "Offline"
I can not make heads and tails out of the home assistant docu about mqtt light. Like, if i use json attributes, i need to parse the json string i get, but since i have only one json_attributes_template, how can i map the extracted values to the attributes like rgb or hue saturation brightness?
