I’m trying to scrape the Kilowatt hours field from this site.
https://sweetwaterutilities.com/Rates.htm
This is what I’ve got.
- platform: scrape
resource: http://www.sweetwaterutilities.com/Rates.htm
select: "#residential_electric_kilowatt_hours"
index: 0
unit_of_measurement: "$/Kwh"
Any idea what I’m doing wrong?
Thanks!
The HTML element does not actually contain the desired data when you fetch the raw HTML. What you see in the web browser is not what the scrape
integration sees.
But you might be in luck, because it appears that the actual data is fetched as JSON from this URL and you could try using the rest
integration to find the value you are looking for: https://utilityservices.orbitmobiles.com/api/data/eRBjUbtFo/Rates
Awesome. Thanks! Took me a minute to figure out how you found that. I didn’t realize I could just plug js/site.js into the path and see the javascript.
