Help with Security Script and Assist
I’m trying to develop a household security check based on this video.
I took his basic example and modified it for my own house. As a standalone script, it works to generate a response for each of the 4 fields depending on which one I select. What I cannot do is figure out how to get it to return a voice announcement of the response when I say “Okay Nabu, run a security check”.
I’ve tried an automation that captures the sentence that I speak in a variable, passes it to the script, which then runs the appropriate action, producing a response with multiple variables. That bit works. The issue I have is getting the script to pass the right response variable back to the automation and having the automation wait until that response is available before proceeding. The camera snapshots part of the script can take 70s to return a response.
The author seems to suggest that simply exposing the script itself to Assist is enough to make the magic happen, but I’m struggling with that too. Custom sentences and Intent Scripts seem to be beyond me currently.
Hers’s part of the script and the response it produces when I run it:
alias: Security Check
sequence:
  - choose:
      - conditions:
          - condition: template
            value_template: >-
              {{ security_query == 'Security Check | Query Motion and Door
              Contact Sensors' }}
        sequence:
          - delay:
              seconds: 2
          - variables:
              response:
                query_all_motion_sensors: |
                  {% set sensors = {
                    'binary_sensor.garage_occupied': '(Garage)',
                    'binary_sensor.living_room_occupied': '(Living Room)',
                    'binary_sensor.kitchen_occupied': '(Kitchen)',
                    'binary_sensor.utility_room_occupied': '(Utility Room)',
                    'binary_sensor.cloakroom_occupied': '(Cloakroom)',
                    'binary_sensor.dining_room_occupied': '(Dining Room)',
                    'binary_sensor.hallway_occupied': '(Hallway)',
                    'binary_sensor.landing_occupied': '(Landing)',
                    'binary_sensor.office_occupied': '(Office)',
                    'binary_sensor.guest_bedroom_occupied': '(Spare Room)',
                    'binary_sensor.seans_room_occupied': '(Seans Room)',
                    'binary_sensor.jamies_room_occupied': '(Jamies Room)',
                    'binary_sensor.master_bedroom_occupied': '(Our Bedroom)',
                    } %} {% for sensor, note in sensors.items() %} {{
                    states[sensor].name if states[sensor] is not none else sensor
                    }}: {{ 'detected' if states[sensor].state == 'on' else 'clear'
                    if states[sensor].state == 'off' else 'unknown' }} {{ note }}
                    |{% endfor %} Be brief and do not list all entities, instead,
                    only mention sensors that are not clear. Do not include emoji
                    and make sure your response is conversational since it is
                    being audibly broadcasted over a speaker system.
                query_all_contact_sensors: |
                  {% set sensors = {
                    'binary_sensor.front_door_sense_contact': '(Front Door)',
                    'binary_sensor.garage_door_left_contact': '(Garage Door Left)',
                    'binary_sensor.garage_door_right_contact': '(Garage Door Right)',
                    'binary_sensor.back_door_sensor_contact': '(Back Door)',
                    'binary_sensor.side_door_sensor_contact': '(Side Door)',
                    'binary_sensor.downstairs_windows': '(Downstairs Windows)',
                    'binary_sensor.upstairs_windows': '(Upstairs  Windows)'
                    } %} Alarm State: {{ states('alarm_control_panel.downstairs')
                    | title }} | {% for sensor, note in sensors.items() %} {{
                    }}: {{ 'open' if states[sensor].state == 'on' else 'closed' if
                    states[sensor].state == 'off' else 'unknown' }} {{ note }} |
                    {% endfor %} Only mention doors/windows that are open. Keep it
                    conversational as this will be audibly broadcasted.
          - stop: Alright. Im done.
            response_variable: response
        alias: Query All Motion and Contact Sensors
fields:
  security_query:
    selector:
      select:
        options:
          - General Security Check | Query Everything
          - Security Check | Query Motion and Door Contact Sensors
          - Security Check | Query Camera Snapshots
          - Security Check | Query Garage Camera Snapshot and Door Sensors
        multiple: false
    description: >-
      Select a query to determine the current status of motion sensors, whether
      or not they are detecting motion, and/or request an analysis of various
      security cameras in the house. This will analyse the most recent snapshot
      from cameras and provide this analysis to you.
    required: true
    default: General Security Check | Query Everything
description: >-
  Use this tool to query motion sensors, contact sensors, and camera snapshots
  in and around the home to give home occupants feedback on motion in and
  outside the home as well as provide an analysis of what the security cameras
  are seeing in the house. Do not include emoji in your response and make sure
  your response is conversational since it is being audibly broadcasted over a
  speaker system.
icon: mdi:security-network
mode: parallel
max: 10
If I run just that part it returns:
query_all_motion_sensors: |-
  garage_occupied: clear (Garage)
    | living_room_occupied: detected (Living Room)
    | kitchen_occupied: clear (Kitchen)
    | utility_room_occupied: clear (Utility Room)
    | cloakroom_occupied: clear (Cloakroom)
    | dining_room_occupied: clear (Dining Room)
    | hallway_occupied: clear (Hallway)
    | landing_occupied: clear (Landing)
    | office_occupied: detected (Office)
    | guest_bedroom_occupied: clear (Spare Room)
    | seans_room_occupied: clear (Seans Room)
    | jamies_room_occupied: clear (Jamies Room)
    | master_bedroom_occupied: clear (Our Bedroom)
query_all_contact_sensors: |-
  Alarm State: Disarmed |  Front Door Sense Door: closed (Front Door) |
     Garage Door Left: closed (Garage Door Left) |
     Garage Door Right: closed (Garage Door Right) |
     Back Door Sensor Door: closed (Back Door) |
     Side Door Sensor Door: closed (Side Door) |
     Downstairs Windows: closed (Downstairs Windows) |
     Upstairs Windows: open (Upstairs  Windows) |
This is where I’m at with the automation:
alias: Check the house is secure via Voice
description: >-
  Runs a Security Check based on voice command and announces the result when
  ready.
triggers:
  - command:
      - Run a security check
      - Check the house security
      - Perform a security check
      - Check for motion
      - Check the doors
      - Check the security cameras
      - Check the garage security
    trigger: conversation
actions:
  - variables:
      query_map:
        Run a security check.: General Security Check | Query Everything
        Check the house security.: General Security Check | Query Everything
        Perform a security check.: General Security Check | Query Everything
        Check for motion.: Security Check | Query Motion and Door Contact Sensors
        Check the doors.: Security Check | Query Motion and Door Contact Sensors
        Check the security cameras.: Security Check | Query Camera Snapshots
        Check the garage security.: Security Check | Query Garage Camera Snapshot and Door Sensors
      selected_query: >
        {{ query_map[trigger.sentence] | default('General Security Check | Query
        Everything') }}
      media_player_entity: >
        {% set assist_device = trigger.device_id %} {% set entities =
        device_entities(assist_device) %} {% set media_player_entity = entities
        | select('search', 'media_player.') | first %} {{ media_player_entity }}
  - action: persistent_notification.create
      title: Media Player ID Debug
      message: "Media Player Response: {{ media_player_entity }}"
      title: Security Query Debug
      message: "Security Query: {{ selected_query }}"
  - data:
      security_query: "{{ selected_query }}"
    action: script.security_check
  - variables:
      response: |
        {% if response.query_all_contact_sensors != '' %}
          {{ response.query_all_contact_sensors }}
        {% else %}
          Nothing to report
        {% endif %}
      title: Script Response Debug
      message: "Script Response: {{ response | default('no response') }}"
  - wait_template: "{{ response }}"
    timeout: "00:00:30"
    continue_on_timeout: true
    enabled: false
  - variables:
      security_response: "{{ state_attr('script.security_check', 'response') | default('') }}"
      error_message: |-
        {% if state_attr('script.security_check', 'last_triggered') is none %}
          The security check script did not run.
        {% elif state_attr('script.security_check', 'response') is none %}
          The security check script did not return a response.
        {% else %}
          An unknown issue occurred.
        {% endif %}
    enabled: false
  - choose:
      - conditions:
            value_template: "{{ security_response | length > 0 }}"
        sequence:
          - data:
              entity_id: "{{ media_player_entity | string }}"
              language: en-GB
              options:
                voice: AlfieNeural
              message: "{{ security_response }}"
            action: tts.cloud_say
    default:
          title: Security Check Failed
          message: "⚠️ Security Check failed: {{ error_message }}"
          notification_id: security_check_error
      - action: tts.cloud_say
          entity_id: "{{ media_player_entity | string}}"
          language: en-GB
          options:
            voice: AlfieNeural
          message: >-
            There was a problem running the security check. {{ error_message }}
            Would you like me to try again?
      - wait_for_trigger:
          - command:
              - "Yes"
              - Try again
              - "No"
              - Cancel
        timeout: "00:00:30"
        continue_on_timeout: false
      - variables:
          retry_response: "{{ wait.trigger.event.data.command | default('No') }}"
      - choose:
          - conditions:
                value_template: "{{ retry_response in ['Yes', 'Try again'] }}"
            sequence:
              - target:
                  entity_id: automation.check_the_house_is_secure_via_voice
                action: homeassistant.turn_on
                data: {}
          - conditions:
                value_template: "{{ retry_response in ['No', 'Cancel'] }}"
            sequence:
              - data:
                  language: en-GB
                  options:
                    voice: AlfieNeural
                  message: Okay, I won't try again.
    enabled: false
mode: single
It’s a work in progress with a few debug actions to check the variables that are being returned. Some work, some don’t.
I think that due to the way the script structures each response, in order to get the right response in the automation I have to do something like this:
 - data:
 - variables:
     response: |
       {% else %}
         Nothing to report
       {% endif %}
but I’d need a statement for every possible response variable and an action for each response.
I’d love to get it working with just a script that does all the legwork then passes the response to my speech engine script for announcement, but stuff like this in the response:
is beyond me. How is this bit even getting to the LLM as a prompt to process this response?
I think the author of the original script is on this forum, so I’m hoping (but not expecting) a steer in the right direction. I’m reasonably competent with scripts, automations, Jinja and variables. It’s the Assist bit with custom sentences in config and intent scripts that I’m struggling with (despite reading the documentation many times). So I just need a steer in the right direction.
In the meantime I’ll keep going and maybe have a Eureka! moment.
Well by golly! I had a sort of Eureka! moment when I figured out I could do everything I needed to in an automation that would run the Security Script, and process the various responses to produce a custom_response to the voice assistant I spoke to.
I just could not get this to work with a custom_sentence and an intent_script in the configuration, despite spending the better part of a day testing and adjusting various configs.
For anyone wanting to try this, my solution might not be the most elegant in terms of minimising the number of processes needed to produce a response, but it works.
Here isthe automation:
description: >-
  ready.
triggers:
  - command:
      - Check for motion
      - Check the doors
actions:
  - variables:
      query_map:
      selected_query: >
        Everything') }}
  - data:
  - variables:
      camera_response: |
        {{ response.camera_check }}
      response: |
        {{ response.query_all_motion_sensors }}
  - wait_template: "{{ camera_response != '' or response != '' }}"
    timeout: "00:00:30"
    enabled: true
  - action: google_generative_ai_conversation.generate_content
    metadata: {}
      prompt: >-
        You are a security guard who has done a sweep of the house. You have
        checked the state of doors and windows and are now reporting your
        findings back to the house owner.   Be brief and tell me tell me the
        state of the alarm, only mention doors or windows that are open and if
        you detected motion anywhere.  Keep it conversational with no emojis as
        your response will be broadcast on a speaker.  Here is the variable with
        the data to check {{ response }}.
    response_variable: security_response
    enabled: true
  - variables:
      full_response: |
        {{ camera_response.text}}  {{ security_response.text }}
      message: "Full Response: {{ full_response }}"
  - set_conversation_response: "{{ full_response.text }}"
    enabled: true
mode: single
I’ve left some of the persistent notification actions in there to help debug variables so you can take them out in the working version.
Here is the script:
sequence:
  - choose:
      - conditions:
            value_template: >-
              {{ security_query == 'General Security Check | Query Everything'
        sequence:
          - action: script.capture_camera_snapshots
            data: {}
          - delay:
              hours: 0
              minutes: 0
              seconds: 25
              milliseconds: 0
          - action: llmvision.image_analyzer
              remember: true
              use_memory: false
              detail: high
              include_filename: false
              target_width: 1600
              max_tokens: 200
              temperature: 0.7
              generate_title: false
              expose_images: true
              provider: <YOUR_PROVIDER>
              message: >-
                You have been invoked for a Security Check. You are a Home
                Automation assistant connected to sensors and systems in a home.
                Attached are snapshots from inside and outside the home. Please
                summarise what you see, within the context of a security check.
                Do not mention anything that seems ordinary. We are looking for
                potential hazards, people, animals etc. Describe those things in
                detail but do not describe the overall scene if there is nothing
                relevant to report in the context of a focused Security check.
                Your response is going to be announced on an audio system so do
                not use any special characters. Make your response
                conversational in paragraph form rather than list form.
              image_file: |-
                /config/www/snapshots/camera1.jpg
                /<CONTINUE FOR  HOWEVER MANY CAMERAS YOU HAVE>
            response_variable: security_cam_snapshot_summary
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - variables:
              response:
                camera_check: |
                  {{ security_cam_snapshot_summary.response_text }}
                  {% set sensors = {
                    '<REPEAT_FOR_ALL_OCCUPANCY_SENSOR>'
                    |{% endfor %}
                  {% set sensors = {
                    '<REPEAT_FOR_ALL_CONTACT_SENSORS>'
                    {% endfor %}
        alias: Query All Motion Sensors and Camera Snapshot Analysis
      - conditions:
            value_template: >-
              Contact Sensors' }}
        sequence:
          - delay:
              seconds: 2
          - variables:
              response:
                  {% set sensors = {
                    '<REPEAT_FOR_ALL_OCCUPANCY_SENSORS>',
                    |{% endfor %}
                  {% set sensors = {
                    {% endfor %}
      - conditions:
            value_template: "{{ security_query == 'Security Check | Query Camera Snapshots' }}"
        sequence:
            data: {}
          - delay:
              hours: 0
              minutes: 0
              seconds: 25
              milliseconds: 0
              remember: true
              use_memory: false
              detail: high
              target_width: 1600
              max_tokens: 200
              temperature: 0.7
              expose_images: true
              message: >-
              image_file: |-
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - variables:
              response:
                camera_check: |
        alias: Query All Camera Snapshots
      - conditions:
            value_template: >-
              {{ security_query == 'Security Check | Query Garage Camera
              Snapshot and Door Sensors' }}
        sequence:
          - action: camera.snapshot
              entity_id: camera.garage_camera_hd_stream
              filename: /config/www/snapshots/camera2.jpg
          - delay:
              hours: 0
              minutes: 0
              seconds: 5
              milliseconds: 0
              remember: true
              use_memory: false
              detail: high
              target_width: 1600
              max_tokens: 200
              temperature: 0.7
              expose_images: true
              message: >-
                Attached is a snapshot from inside a garage. Please summarise
                what you see, within the context of a security check. Do not
              image_file: /config/www/snapshots/camera2.jpg
            response_variable: garage_cam_snapshot_summary
          - delay:
              hours: 0
              minutes: 0
              seconds: 5
              milliseconds: 0
          - variables:
              response:
                camera_check: |
                  {{ garage_cam_snapshot_summary.response_text }}
                  {% set sensors = {
                    |{% endfor %}
                  {% set sensors = {
                    {% endfor %}
        alias: Query Garage Door Sensors and  Camera
fields:
  security_query:
    selector:
      select:
        options:
        multiple: false
    description: >-
    required: true
description: >-
  speaker system.
mode: parallel
max: 10
