Control
December 21, 2023, 6:25am
1
Hi
I have 3 select template as below
select:
name: Source_1 Priority"
icon: mdi:format-list-bulleted
optimistic: true
restore_value: true
options:
- "First"
- "Second"
- "Third"
name: Source_2 Priority"
optimistic: true
restore_value: true
options:
- "First"
- "Second"
- "Third"
name: Source_3 Priority"
optimistic: true
restore_value: true
options:
- "First"
- "Second"
- "Third"
I need to set automation between them as if I select First option from any of 3 replace this option from the other and vice versa for others
in other words, I need always have options First, Second, and Third in one of select template not to be duplicated in other
zoogara
(Daryl)
December 21, 2023, 6:38am
2
First question - I assume that if you select a value, the prior select value replaces that in the select template that previously had the new value chosen?
That is - if a select has a value of First and I replace it with Second, the select that had a value of Second now becomes First?
zoogara
(Daryl)
December 21, 2023, 8:10am
4
Ok - this is a bit hacky but it works (so far):
globals:
- id: source1_index
type: int
restore_value: true
initial_value: '0'
- id: source2_index
type: int
restore_value: true
initial_value: '1'
- id: source3_index
type: int
restore_value: true
initial_value: '2'
select:
optimistic: true
restore_value: true
initial_option: "First"
options:
- "First"
- "Second"
- "Third"
on_value:
lambda: |-
auto index2 = id(Source_2_Priority).active_index();
auto index3 = id(Source_3_Priority).active_index();
if (index2.value() == i) {
auto call = id(Source_2_Priority).make_call();
call.set_index(id(source1_index));
call.perform();
id(source1_index) = i;
} else {
if (index3.value() == i) {
auto call = id(Source_3_Priority).make_call();
call.perform();
optimistic: true
restore_value: true
initial_option: "Second"
options:
- "First"
- "Second"
- "Third"
on_value:
lambda: |-
auto index1 = id(Source_1_Priority).active_index();
if (index1.value() == i) {
auto call = id(Source_1_Priority).make_call();
call.set_index(id(source2_index));
call.perform();
id(source2_index) = i;
} else {
call.perform();
optimistic: true
restore_value: true
initial_option: "Third"
options:
- "First"
- "Second"
- "Third"
on_value:
lambda: |-
call.set_index(id(source3_index));
call.perform();
id(source3_index) = i;
} else {
call.perform();
Control
December 21, 2023, 8:32am
5
@zoogara thanks for your code
ESP8266 crashe and reboot when selecting between options
zoogara
(Daryl)
December 21, 2023, 8:34am
6
Ah. Well was tested on an ESP32. Maybe you have memory issues.
Are you using idf or Arduino platform?
zoogara
(Daryl)
December 21, 2023, 8:42am
8
Yeah sorry ignore that, you don’t really have a choice with ESP8266.
Umm no idea really. If you are using one of those multi relay boards with embedded ESP8266 then you are stuck with limited memory. Otherwise try with an ESP32.
Maybe someone else can think of an approach that uses less lambda.
Control
December 21, 2023, 9:13am
9
@zoogara thanks i try my best
