Help with selector in addon run script - bashio
I could really use help with my addon/run script. Thanks
I want option 1 to run bluetooth.sh or else option 2 runs Ethernet.sh depending on the corresponding selection.
I either end up with unbound or bad substitution errors if I move the " " ( ) { } around
I have looked at bashio config.sh and bashio jq.sh I can’t say I follow much there.
I have a selector option on my addon user config
  • Bluetooth
  • Ethernet
That is pushed to options.json as
"Connection_Type": "Bluetooth"
or
"Connection_Type": "Ethernet"
When my run script starts… I would like to do
##CONFIG_PATH=/data/options.json <---- not needed
value=$(bashio::config "${"Connection_Type":=}")
If bashio::config.equals Bluetooth; then
bashio::log.info Generating Bluetooth Config
exec /usr/bin/bluetooth.sh
fi
else
If bashio::config Ethernet; then
bashio::log.info Generating Ethernet Config
exec /usr/bin/ethernet.sh
fi
fi
This is the example I was trying to follow. I am not really sure how to fill it out however. I am also not sure how to pair it up to run the second Ethernet part. Basically I am not sure of the syntax and which keys to manually change vs pull in from options. Do I need to use bashio::jq
function bashio::config.equals() {
    local key=${1}
    local equals=${2}
    local value
    bashio::log.trace "${FUNCNAME[0]}:" "$@"
    value=$(bashio::config "${key}")
    if ! bashio::var.equals "${value}" "${equals}"; then
        return "${__BASHIO_EXIT_NOK}"
    fi
    return "${__BASHIO_EXIT_OK}"
Whole block here
#!/usr/bin/with-contenv bashio
# Start the service
# s6-overlay docs: https://github.com/just-containers/s6-overlay
set -x
# --- GENERATE CONFIG --
echo "PWD is current directory $(pwd)"
cd /
    local key=${1}
    local equals=${2}
    local value
    bashio::log.trace "${config.equals[0]}:" "$@"
    value=$(bashio::config "${Connection_Type:=}")
    if ! bashio::var.equals "${value}" "${Bluetooth}"; then
    bashio::log.info
    bashio::log.info "[Bluetooth being setup]"
    bashio::log.info
    /usr/bin/my_addon/genBluetoothConfig.sh
    fi
    # return "${__BASHIO_EXIT_OK}"
    value=%(bashio::config "${Connection_Type:=}"); then
    if ! bashio::var.equals "${value}" "${Ethernet}"; then
    bashio::log.error
    bashio::log.error "Ethernet being setup"
    bashio::log.error
    /usr/bin/my_addon/genEthernetConfig.sh
   fi
# ---- Print Host BT Controller and sys info
bashio::log.info
bashio::log.info echo "$(uname -smrv)"
bashio::log.info
## Get the 'message' key from the user config options.
message=$(echo "[Host Bluetooth MAC Address] $(bluetoothctl list)")
## Print the message the user supplied, defaults to "Hello World..."
bashio::log.info
bashio::log.info "${message:="Hello World..."}"
bashio::log.info
# ---- RUN ----
echo 'Starting daemon'
# cron
bashio::log.info echo '$('Starting cron in foreground')'
exec /usr/sbin/crond -f
Figured it out eventually,
From /data/options.json <------Switched by addon frontend config
"Connection_Type":"Bluetooth" or "Connection_Type":"Ethernet"
set -x  <-----debugging
value=$(bashio::config 'Connection_Type')
if  bashio::var.equals "${value}" "Bluetooth"; then
    bashio::log.info
    message=$(echo "||    Generating Bluetooth Configs    ||")
    bashio::log.info ${__BASHIO_COLORS_BLUE} "${message:=""}"
    bashio::log.info
elif bashio::var.equals "${value} "Ethernet"; then
    bashio::log.info
    message=$(echo "||    Generating Ethernet Configs     ||")
    bashio::log.info ${__BASHIO_COLORS_MAGENTA} "${message:=""}"
    bashio::log.info
else
    bashio::log.info ${__BASHIO_COLORS_RED} ================================
    bashio::log.info ${__BASHIO_COLORS_RED} "Setup failed to create Configs"
fi
set +x
Hope it helps someone else!
