I want to calculate the Free Disk Space in percentage for Volume 1 from a Synology Diskstation. Therefor I created 3 SNMP-sensors:
# Berechnungen fuer Volume 1
# Volume 1 Groesse der Bloecke in Bytes:
- platform: snmp
host: 192.168.178.99
community: public
baseoid: 1.3.6.1.2.1.25.2.3.1.4.1
unit_of_measurement: "Bytes"
# Volume 1 Anzahl der Bloecke in Bytes insgesamt:
- platform: snmp
community: public
baseoid: 1.3.6.1.2.1.25.2.3.1.5.1
# Volume 1 Anzahl der belegten Bloecke in Bytes:
- platform: snmp
community: public
baseoid: 1.3.6.1.2.1.25.2.3.1.6.1
All three sensors get valid values. But the calculation of the Percentage seems to be wrong and get a “non numeric” error.
# Benutzter Platz Volume 1
sensors:
supernova_volume1_used_space_percent:
friendly_name: "SuperNova Volume 1 Used Space"
value_template: >
{% set usedspace = (states('supernova_volume1_block_size')| float) * (states('supernova_volume_1_blocks_used')| float) %}
{% set maxspace = (states('supernova_volume1_block_size')| float) * (states('supernova_volume_1_blocks')| float) %}
{{ (((usedspace / maxspace) | float) | round(0)) }}
unit_of_measurement: "%"
I am not a Pro in YAML so I can’t see the error. Can someone help me?
Why don’t you use the synology “integration”?
I have the 2-Factor-Autentication for admins on the synology activated and don’t want to deactivate this security feature. But with the 2FA i can’t use the synology integration.
Ah, pity. Can’t make a very complex user and pass without 2fa?
No. Synology wants the 2FA just for all admins or for no one. And the user must be an admin to use the synology integration. So for me the best way is to work with SNMP.
Now here is the correct calculation, after finding some errors in the above code. It works fine:
# Volume 1 Free Space
- platform: snmp
community: public
baseoid: .1.3.6.1.4.1.6574.3.1.1.4.1
version: '2c'
unit_of_measurement: "TB"
value_template: >
{{ (((value | float) / 1099511627776) | round(2)) }}
# Volume 1 Size
- platform: snmp
community: public
baseoid: .1.3.6.1.4.1.6574.3.1.1.5.1
version: '2c'
value_template: >
# Benutzer Platz Volume 1 absolut
sensors:
supernova_volume1_used_space:
value_template: >
{% set free_space = states.sensor.supernova_volume1_free_space.state | float %}
{% set size = states.sensor.supernova_volume1_size.state | float %}
{{ (((size - free_space) | float) | round(2)) }}
# Benutzter Platz Volume 1 in Prozent
sensors:
friendly_name: "SuperNova Volume 1 Used Space Percent"
value_template: >
{% set usedspace = (states.sensor.supernova_volume1_used_space.state | float) %}
{{ (((usedspace / size) * 100 ) | round(0)) }}
