Felix_1
(Felix)
May 17, 2019, 2:26pm
1
Hi!
I have created an template for showing three diffrent states for my robotic mower.
It consist of a timer and an binary sensor that senses if the mower is docked in the station or not.
The code looks like this: (Binary ON = Mowing)
sensors:
status_am:
value_template: >-
{% if states.binary_sensor.opencloseam.state == 'on' %}
Mowing
{% elif states.timer.chargning_am.state == 'idle' %}
Docked
{% else %}
Chargning
{% endif %}
If the mower is NOT inte the docked position = Mowing
If the mower recently came back to the station = Charging (always takes 1,5h)
If the mower have been in the station for 1,5h it is Docked (and waitinig)
I also want to add the stage “Stuck”, if the binary sensor have been in the “on” position (Mowing) for more than 3h. The mower is probably stuck somewhere.
I am not sure how to do this. I was thinking somehing like (code below) this but I do not know how to use AND criterion inside templates lite this
sensors:
status_am2:
value_template: >-
Mowing
{% elif is_state("timer.mowtime_am", "idle") and
is_state("binary_sensor.opencloseam", "on") -%}
Stuck
{% elif states.timer.mowing_am.state == 'idle' %}
Docked
{% else %}
Charging
{% endif %}
The timers works like this:
- alias: status-am
platform: state
entity_id: binary_sensor.opencloseam
to: 'off'
- service: timer.start
entity_id: timer.charging_am
- alias: status-am-stuck
platform: state
to: 'on'
entity_id: timer.mowing_am
Maybe:
sensors:
status_am2:
value_template: >
{% if is_state('binary_sensor.opencloseam', 'on') %}
{% if is_state('timer.mowtime_am', 'idle') %}
Stuck
{% else %}
Mowing
{% endif %}
{% elif is_state('timer.mowing_am.state', 'idle') %}
Docked
{% else %}
Charging
{% endif %}
Felix_1
(Felix)
May 18, 2019, 8:10am
3
Thank you so much!!!
Had to do some minor changes but otherwise it seems to work flawless
This is my final code:
sensors:
status_am2:
value_template: >
Stuck
{% else %}
Mowing
{% endif %}
{% elif is_state('timer.charging_am', 'idle') %}
Docked
{% else %}
Charging
{% endif %}
automation:
- alias: status-am
platform: state
to: 'off'
platform: state
to: 'on'
entity_id: timer.mowtime_am
timer:
chaging_am:
duration: 01:10:00
mowtime_am:
duration: 02:20:00
Felix_1
(Felix)
May 18, 2019, 8:27am
4
One problem tho, if I restart HA the sensor will always show “stuck” due to timers getting also getting reset.
Maybe there’s a way to create an automatic start of the timers when HA is restarted
- alias: status-am
- platform: state
to: 'off'
- platform: homeassistant
event: start
condition:
- condition: state
state: 'off'
- platform: state
to: 'on'
event: start
condition:
- condition: state
state: 'on'
Felix_1
(Felix)
May 18, 2019, 12:44pm
6
Clever! I have this implemented now
