Make a template switch
i follow the instructions but for some reason the template switch doesnt sync with the device service switch (climate.turn_on / climate.turn_off)
switches:
dehumidifier_1:
entity_id: climate.midea_dehumi_1
friendly_name: Dehumidifier
value_template: "{{ is_state('climate.midea_dehumi_1', 'off') }}"
turn_on:
service: climate.turn_on
turn_off:
service: climate.turn_off
change to âonâ
doesnt solve the problem
any errors in the logs? homeassistant.log, not the gui
probably wonât solve it either, and I donât have a climate switch, but why donât you try:
dehumidifier_1:
value_template: >
{{ is_state('climate.midea_dehumi_1', 'on') }}
turn_on:
turn_off:
you have an entity_id listed under the switch name, which is not documented Template Switch - Home Assistant
also, when no extra data is needed in the service, you can leave the data field out⌠(which is contrary to the doc)
Ok⌠this entity relies on this github ( https://github.com/barban-dev/midea_inventor_dehumidifier )
and hassio states itâs an untested component by the hassio team (warning) so i know that there may be issues implementing it.
Iâve tried every possible solution coding but i get this:
- when device is off (while this switch is off) the switch works and it turns the dehumidifier on
- when device is on (while the switch is on) the switch doesnt work, it doesnt turn the dehumidifier off and the switch goes from on to off
- the switch doesnt sync automatically with the state of the device. If the device is on when opening hassio (from web or the app) the switch appears off
can you switch it off via the dev-service page?
please show us the various states in the dev-state page by screenshot, so we can see what state and attributes the entity has.
I can switch it on or off calling the respective services for the entity in the Dev service section (climate.turn_on or climate.turn_off services for the entity)
or even with this code in ui-lovelace.yaml (in a card):
- type: entities
show_header_toggle: false
entities:
- type: call-service
icon: mdi:power
action_name: Off
..... same code for climate.turn_on
and they work
Well that says it all⌠you have to check for the state . So âtarget_mode-ion_onâ should be in the value_ template
doesnt the value_template return true or false which equals on or off for the switch?
your value template evaluates the state. And checks it to be the âonâ state. Normally, with switches, lights, input_booelans, etc etc, that would be either âonâ or âoffâ. As @petro suggested before.
Hence the
AS youâve said, it doesnât follow the true state of the climate entity. Thats why I asked you to show the dev-state page.
Your screenshot clearly shows the state to be âtarget_mode-ion_offâ which I presume to be the state for âoffâ. Since we want to know the state for âonâ I take it it would be âtarget_mode-ion_onâ
Did you give it a try?
dehumidifier_1:
value_template: >
{{ is_state('climate.midea_dehumi_1', 'target_mode-ion_on') }}
turn_on:
turn_off:
the turn_on and turn_off commands are fine, as you confirm, its just the state being evaluated wasnât the right oneâŚ
yes, youâre absolutely right.
Iâve realised that 10minutes prior to your reply.
It seems that the switch needs to evaluate correctly the value_template is_state otherwise it wont work properly.
For that reason, instead of âonâ i need to check if the device is set on one of the following states:
âtarget_mode-ion_onâ,
âcontinuos_mode-ion_onâ,
âsmart_mode-ion_onâ,
âdryer_mode-ion_onâ,
âtarget_mode-ion_offâ,
âcontinuos_mode-ion_offâ,
âsmart_mode-ion_offâ,
âdryer_mode-ion_offâ
I tried it with target_mode-ion_on and the switch worked just fine turning the device on and off
ok once the issue was identified it was a matter of timeâŚ
hereâs the working code⌠finally:
switches:
dehumidifier_1:
value_template: >-
{% if is_state("climate.midea_dehumi_1", "target_mode-ion_on") or
is_state("climate.midea_dehumi_1", "target_mode-ion_off") or
is_state('climate.midea_dehumi_1', 'smart_mode-ion_on') or
is_state('climate.midea_dehumi_1', 'smart_mode-ion_off') or
is_state('climate.midea_dehumi_1', 'continuos_mode-ion_on') or
is_state('climate.midea_dehumi_1', 'continuos_mode-ion_off') or
is_state('climate.midea_dehumi_1', 'dryer_mode-ion_on') or
is_state('climate.midea_dehumi_1', 'target_mode-ion_off')%}
True
{% else %}
False
{% endif %}
for anyone else with the same dehumidifier
make that:
value_template: >-
{{ is_state("climate.midea_dehumi_1", "target_mode-ion_on") or
is_state('climate.midea_dehumi_1', 'target_mode-ion_off') }}
or:
value_template: >
{{ states('climate.midea_dehumi_1') in
['target_mode-ion_on', 'target_mode-ion_off', 'smart_mode-ion_on','smart_mode-ion_off','continuos_mode-ion_on',
'continuos_mode-ion_off','dryer_mode-ion_on', 'target_mode-ion_off'] }}
tried it, replacing the " with â
but it doesnt pass the validation code
not really sure what you are saying here? please post the code you tried?
your first suggestion didnât pass the validation code
but your second suggestion with the table not only is it brilliant and clean but it passed validation and it works.
Thank you
cool, glad to be of help. enjoy!
Hi all, i have a simple Aqara one-button switch, and I just want to use a simple code: if state of the light is on, then turn it off, else turn it on.
I read 100 forums but I canât get it to work. What is wrong with my code?
- id: '1576885798868'
alias: Kitchen Switch ON-OFF
description: ''
- event_data:
event: 1002
event_type: deconz_event
platform: event
condition: []
- service_template: >
{% if is_state('light.kitchen_lights'), 'on' %}
script.kitchen_lights_off
{% else %}
script.kitchen_lights_on
{% endif %}
Note that the two scripts are working fine. If I trigger them independently, the lights turn on and off, as expected. The trigger also works fine. The logs show the automation triggered.
