Bracket is in the wrong place, should be
{% if is_state('light.kitchen_lights' , 'on') %}
oh, thanks a lot, Marc!
This Jinja syntax is crazy. I wish we could use simple python.
You can use appdaemon if you want to speak to homeassistant in python.
The OP question might also be an indentation issue.
I had the same problem, and was fixed by adding 2 spaces to beginning of the equivalent of these lines:
{% if is_state('binary_sensor.door_window_sensor_158d0001fd55d5', 'on') %}
rest_command.set_climate_to_on
{% elif is_state('binary_sensor.door_window_sensor_158d0001fd55d5', 'off') %}
climate.set_operation_mode
I have this script but keep getting error: String does not match the pattern of “DEPRECATED”
script:
rainbird_irrigate:
sequence:
- service_template: >
{% if is_state('input_boolean.zone1', 'on') %}
script.rainbird_zone1
{% elif is_state('input_boolean.zone2', 'on') %}
script.rainbird_zone2
{% elif is_state('input_boolean.zone3', 'on') %}
script.rainbird_zone3
{% elif is_state('input_boolean.zone4', 'on') %}
script.rainbird_zone4
{% endif %}
change service_template to service
