Help with Servo Motors YAML file
Hi, All,
So I have this yaml code on ESPHome 2024.6.2, which was working fine on 2022.3.1, but now I am always getting an error when trying to update the device:
ERROR Circular dependency detected! Please run with -v option to see what functions failed to complete.
Here is the actual yaml file:
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  services:
    - service: control_servo
      variables:
        level: float
      then:
        - servo.write:
            level: !lambda 'return level / 100.0;'
        - servo.write:
            level: !lambda 'return level / -100.0;'
ota:
  - platform: esphome
    password: "secret_pass"
safe_mode:
  num_attempts: 3
  disabled: true
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Roomba-Garage Fallback Hotspot"
    password: "fallback_password"
captive_portal:
# Sync time with Home Assistant.
time:
  - platform: homeassistant
globals:
  - id: roomba_garage_door
    type: bool
    restore_value: no
    initial_value: 'false'
#binary_sensor:
#  - platform: gpio
#    pin: D8
#    name: "Vacuum garage door button"
#    on_press:
#      then:
#        - switch.turn_on: vaccum_garage_door
#    on_release:
#      then:
#        - switch.turn_off: vaccum_garage_door
switch:
    name: "Roomba Garage Door"
    restore_mode: DISABLED
    turn_on_action:
      - servo.write:
         level: 100%
      - servo.write:
         level: -100%
      - globals.set:
          value: 'true'
    turn_off_action:
      - servo.write:
         level: -10%
      - servo.write:
         level: 10%
      - globals.set:
          value: 'false'
    lambda: return id(roomba_garage_door).state;
servo:
  - id: servo_right
    output: pwm_output_right
    restore: true
    transition_length: 2s
  - id: servo_left
    output: pwm_output_left
    restore: true
output:
  - platform: esp8266_pwm
    pin: GPIO4
    frequency: 50 Hz
    pin: GPIO5
    frequency: 50 Hz
Can someone please guide me on what am I missing?
I am getting the same error with safe mode disabled, for now it seems you have to have it enabled or disable the ota component to default safe mode to off.
Adding this to any config seems to make it fail:
safe_mode:
  disabled: true
Perfect. That did the trick.
Thanks a lot for the help
It seems to be fixed in the latest release (2024.6.3)
