I’m running into an issue with the last step of setting up Z Wave JS UI. I have the Z-Wave JS successfully added to the sidebar, and I can see my Z Wave devices connected inside of that.
The next step was to connect it to HA so that I could access the ZWave entities.
When I try and add the integration on the Devices and Services screen.
I select “Setup another instance of Z-Wave”
I am sure to unselect “use the Z-Wave JS Supervisor Addon”
When it asks for the URL I have tried “ws://localhost:3000” and “ws://a0d7b954-zwavejs2mqtt:3000”, but both will error and say 'Failed to Connect"
When I first tried to setup the new ZWave JS, I did accidently install the non UI version. I have now uninstalled that.
Apologies for the rudimentary question. I have not touched the HA in 3 years, and was forced to update it when cloud control stopped allowing me to access it due to it being so far out of date.
