Help with Shell commands
Hi there !
I plan to use this terminal command on automation.
1st step is to create shell command.
I have this message :
“Invalid config for [shell_command]: expected dictionary for dictionary value @ data[‘shell_command’]. Got [{‘mesure_forced’: “mosquitto_pub -h my_ip_address -p PORT -m “” -t ‘blueriiot/commands/release_last_unprocessed/ID’ -u ‘username’ -P ‘password’”}]. (See /config/configuration.yaml, line 50).”
Here is the command to execute :
mosquitto_pub -h my_ip_address -p PORT -m “” -t ‘blueriiot/commands/release_last_unprocessed/ID’ -u 'username' -P 'password'
Ok on terminal but not on config.yaml
Regards
You have written something incorrectly to get that error message. Please paste that section of your configuration.yaml, properly formatted using the </> button or by surrounding with three backticks (```). Formatting should look like this:
shell_command:
  mesure_forced: [etc]
I write this on config.yaml
shell_command:
  - mosquitto_pub -h my_ip_address -p 1883 -m “” -t ‘blueriiot/commands/release_last_unprocessed/ID’ -u ‘username’ -P ‘password$'"
Lots of mistakes there, and that code (without mesure_forced) didn’t generate that error message (with mesure_forced).
  • no name for the shell command;
  • “smart” quotes which are probably copy-paste form the forum post. You must use simple single and double quotes: ' and ", not or ;
  • double quote at the end that doesn’t match with anything earlier.
Should look like this, as per the docs:
shell_command:
  mesure_forced: mosquitto_pub -h my_ip_address -p 1883 -m '' -t 'blueriiot/commands/release_last_unprocessed/ID' -u 'username' -P 'password$'
That should work if your HA installation has mosquitto_pub in its internal shell path. If it doesn’t (and perhaps a better alternative anyway) is to use the mqtt.publish service:
Helpfull answer, no error now :wink:
When i use this command on Terminal, it succeed.
But publishing via MQTT is interesting.
Could you give me the way to do this please ?
Just call the service in an automation. I don’t know how you do that with an empty message though.
