I’m trying to replace an Eachen Smart On Off with a Shelly but the wiring labels don’t quite match up. The Eachen needs to come out and the Shelley is going in.
I can see where the L and N go, and Switch seems to have a direct replacement but I’m unsure about the In and Out.
Just a comment on your installation … I don’t know where you are located but in the UK this would not comply with wiring regulations as the white circular terminal cover has been removed to allow the smart switch to be connected which leaves live terminals exposed. Ideally you should put this in a larger plastic junction box so that there are no exposed terminals. These smart switches are designed to go behind standard switch plates which provide the necessary protection.
I am not trying to have a go but just letting you know in case this could be a problem.
