Im playing around with motion and timers, so that lights come on and go off.
The slider seems to work well, however i want to show in teh UI, how long until the timer is “finished” - eg. you have 1 minute until times is out and the lights go off.
i cant work out how to use the timer, to populate the value from the slider when its triggered dynamically based on when the automation is triggered?
config:
timer:
timer_motion_kitchen:
duration: '00:15:00' ##<---???????? what should this be, as i want it to be dynamic, based on the slider value used in the automation
input_number:
timer_kitchen_motion_slider:
name: Timer Kitchen Motion Timer
initial: 5
min: 5
max: 120
step: 5
############### kitchen ###############
- id: kitchenlightsonmotion
alias: kitchen lights on motion
- entity_id: binary_sensor.motion_sensor_kitchen_motion
platform: state
to: 'on'
condition:
condition: state
entity_id: sun.sun
state: below_horizon
service: timer.start
entity_id: timer_motion_kitchen
service: light.turn_on
entity_id:
- light.kitchen_deconz
- id: kitchenlightsoffafter30minnomotion
alias: kithcen lights off no motion slider
platform: state
to: 'off'
for:
minutes: "{{ states('input_number.timer_kitchen_motion_slider')|int }}"
- service: light.turn_off
entity_id:
@property
def state_attributes(self):
"""Return the state attributes."""
return {
ATTR_DURATION: str(self._duration),
ATTR_REMAINING: str(self._remaining),
So if you use a timestamp.now() + remaining
You can work out when it will finish as well
You best way to implement this is in the off automation set a delay and use the ‘00:{{inputslider}}:00’.
I don’t think you can change the timer itself.
So your automations turn the light on when motion is first detected, and off when there has been no motion detected for the number of minutes specified by the input_number. (Accept that there are typos in your first automation, so it won’t work as is.)
I think what you’re asking for is to be able to display the amount of time left before the second automation triggers and turns off the light. Is that it?
If so, I’m not sure there’s any way to do that, since there’s no knowing how long binary_sensor.motion_sensor_kitchen_motion will be in the 'on' state, even after it stops detecting motion. (Most motion detectors stay “on” for a minimum amount of time, even without further motion.)
thanks! this is what i wanted to do
ideally, having the light flash quickly when there was only 1 min left before going off (eg. wave your arms around, the lights will go off and you have been sat around on the sofa too long!)
If that’s what you’re trying to do, then you don’t really need to show the amount of time left in the UI. You could just do something like the following (which doesn’t need a timer):
platform: state
to: 'on'
condition:
- condition: state
entity_id: sun.sun
- service: light.turn_on
entity_id: light.kitchen_deconz
alias: kitchen lights off no motion slider
- platform: state
to: 'off'
for:
- alias: kitchen lights off warning
- platform: state
to: 'off'
for:
minutes: "{{ states('input_number.timer_kitchen_motion_slider')|int - 1 }}"
- delay:
seconds: 2
The last automation will trigger one minute earlier than the automation that turns the light off. It will “flash” the light off & back on as a warning. If motion is then detected in the next minute then the automation that turns the light off will not fire (and its “timer” will restart.)
If you light supports flashing then the action in the last automation could be changed to this:
flash: short
Not sure about this because I don’t have a light that supports the flash parameter.
