Hello everyone,
I have a sonoff pow r2 flash with the latest esphome firmware.
The problem I am facing is this. I am trying to store the today, yesterday and total energy values to the flash memory so that they get restored after power failure. This is working but when I update the firmware to a later version (wirelessly) yesterday value gets restored properly after the update but today and total values are erased. Why?
Any ideas?
Here is my yaml file.
substitutions:
device_name: sonoff-pow-r2-01
device_ip: 192.168.10.94
packages:
wifi: !include common/wifi.yaml
web_server: !include common/web_server.yaml
ota: !include common/ota.yaml
api: !include common/api.yaml
text_sensor: !include common/text_sensor.yaml
sensor: !include common/sensor.yaml
esphome:
on_boot:
priority: -100
then:
lambda: |-
id(yesterday_energy).publish_state(id(energy_yesterday)); // Copy restored global variable energy_yesterday to yesterday_energy sensor
esp8266:
board: esp01_1m
# Restores writen sensor values from flash
restore_from_flash: True
preferences:
# Saves sensor values to flash every... There must also be a "restore_from_flash : True" in "esp8266:" for it to work
flash_write_interval: 60min
# Enable logging
logger:
baud_rate: 0
#wifi:
#use_address: x.x.x.x # In case we need to change the ip address (this is the old address). When done comment out these lines
# Enable Home Assistant API
api:
encryption:
key: "--------------------------------------------------------"
globals:
- id: energy_yesterday
type: float
restore_value: yes
initial_value: '0'
time:
- platform: homeassistant
on_time:
# Just before every midnight
- seconds: 59
minutes: 59
hours: 23
then:
# Copy last total_daily_energy sensor value of the day, to global variable energy_yesterday
# Publish to yesterday_energy sensor the value of total_daily_energy sensor
lambda: |-
id(energy_yesterday) = id(daily_energy).state;
id(yesterday_energy).publish_state(id(daily_energy).state);
captive_portal:
# Device specific Config Begins Below #
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: fakebutton
button:
- platform: factory_reset
name: ${device_name}_Restart with Factory Default Settings
switch:
optimistic: true
lambda: 'return id(relay).state;'
turn_on_action:
- switch.turn_on: relay
- light.turn_on: led
turn_off_action:
- switch.turn_off: relay
- light.turn_off: led
- platform: gpio
pin: GPIO12
#restore_mode: RESTORE_DEFAULT_OFF
restore_mode: ALWAYS_ON
output:
- platform: esp8266_pwm
pin:
number: GPIO13
inverted: True
light:
- platform: monochromatic
output: pow_blue_led
uart:
rx_pin: RX
baud_rate: 4800
# Power & Energy Sensors start here
- platform: cse7766
update_interval: 2s
current:
device_class: "current"
state_class: measurement
unit_of_measurement: A
filters:
- or:
- throttle: 90s
- delta: 0.1
voltage:
device_class: "voltage"
unit_of_measurement: V
filters:
- calibrate_linear:
# Map 0.0 (from sensor) to 0.0 (true value)
- 0.0 -> 0.0
- 237.7 -> 236.2
- or:
- throttle: 90s
- delta: 2
power:
device_class: "power"
unit_of_measurement: W
#accuracy_decimals: 0
filters:
#- calibrate_linear:
#- 0.0 -> 0.0
#- 9.7 -> 10.9
#- 945.2 -> 938.9
- or:
- throttle: 90s
- delta: 5
energy:
internal: True # Don't expose this sensor
device_class: "energy"
state_class: total_increasing
unit_of_measurement: kWh
accuracy_decimals: 3
filters:
- multiply: 0.001
- platform: total_daily_energy
#state_class: total_increasing
power_id: power
method: right
filters:
- multiply: 0.001
- platform: integration
sensor: power
integration_method: right
time_unit: h
filters:
- multiply: 0.001
internal: True # Internal components will not be exposed to Home Assistant
lambda: return id(power).state / id(voltage).state / id(current).state;
filters:
- filter_out: nan
filters:
- filter_out: nan
