Help with Spotify and Linkplay
I’m trying to get Spotify on the dashboard with media browse functionality and a speaker selector.
I have the Official Spotify integration installed as well as Spotcast.
All players are Up2Stream Amps installed via the linkplay integration.
Spotify player or Media player only works when I start playing spotify on mobile first. Otherwise it’s blank. Any other ways to make this work with multiroom support?
Did you ever find the fix or a solution?
Use media_player.select_source on your Spotify media player (from the Spotify integration), where the source is the name of the Linkplay speaker or group.
Then you can use media_player.play_media along with a media_content_id for your playlist or song which you can get from the Spotify app.
More info at the bottom of this page:
Here’s a script that will select the Linkplay source and start a playlist:
  - action: media_player.select_source
      source: YourSpeakerGroupName
      entity_id: media_player.spotify_your_name
  - action: media_player.play_media
      media_content_id: spotify:playlist:37i9dQZF1DZ06evO2sSGze
      media_content_type: spotify://playlist
The SpotifyPlus Integration can do this as well (SpotCast not required).
service: spotifyplus.player_media_play_context
  entity_id: media_player.spotifyplus_your_name
  context_uri: spotify:playlist:37i9dQZF1DZ06evO2sSGze
  device_id: YourSpeakerGroupName
Ha, I realized my post wasn’t totally true after running into some problems getting the music to start up again.
SpotifyPlus solves those problems by letting you set a default Source in the integration configuration.
