trying to change a zwave node state from is_failed: false to is_failed_true. The docs are not at all clear on how to do this. Once I select the entity in the drop down i then have to populate one of two fields (State, State Attributes) or perhaps both. I’ve tried every combination I can think of as follows:
“is_failed”: true
“is_failed”:“true”
{“is_failed”:“true”}
I’ve tried these entries in either of the two fields and I can’t get the state to change. What am I doing wrong?
