Invalid config for [automation]: expected a dictionary. Got [OrderedDict([(‘alias’, ‘Write Stepper Value to ESP’), (‘trigger’, None), (‘platform’, ‘state’), (‘entity_id’, ‘input_number.stepper_control’), (‘action’, [OrderedDict([(‘service’, ‘esphome.steppermotor_control_stepper’), (‘data_template’, None), (‘target’, ‘{{ trigger.to_state.state | int }}’)])])])]. (See /config/automation/Gardin.yaml, line 1). Please check the docs at https://home-assistant.io/components/
# Control stepper motor
- alias: 'Write Stepper Value to ESP'
platform: state
entity_id: input_number.stepper_control
- service: esphome.steppermotor_control_stepper
data_template:
target: '{{ trigger.to_state.state | int }}'
platform: state
data_template:
Check the names of your enitity ID and service names to make sure that was what has been created. When I first did mine, the entity ID didn’t match what I thought it should be from following the instructions.
Hi
Just found out that i am using a directory with all my automation files inside and they are all working except for the one mentioned above, but if I instead of directory try using the automation.yaml file and only with the automation above it is working like a dream.
But why is it giving me error when using the same thing I directory.?
Hope you know what I mean
