Would love to use the stream component but how would I go about installing the packages for it in a FreeNAS jail? https://www.home-assistant.io/components/stream/
FreeNas wants nothing to do with:
This is a debian/ubuntu install command. You will need to find similar packages available for FreeBSD, and use pkg install. Also, make sure you are doing this INSIDE the jail and not on FreeNAS.
