HELP with system crashing after updates
Hello - I am hoping that someone here can assist with my issues. My system has been stable up until today. I am running OS on virtual box and it wasn’t until after I installed both the Core and OS updates that the system started behaving poorly, and by poorly I mean unusable. I am able to reboot everything and access the web interface for about a minute or two then get the popup at the bottom of the page that states that it is disconnected and reconnecting. I was able to grab a screen shot of the log but that is all I can get before if freezes up again. Any assistant would be greatly appreciated as I am trying to avoid a complete rebuild! thanks is advance!
2024-12-06 10:22:00.745 ERROR (MainThread) [asyncio] Task was destroyed but it is pending!
task: <Task pending name=‘Task-647’ coro=<Event.wait() done, defined at /usr/local/lib/python3.12/asyncio/locks.py:199> wait_for=>
2024-12-06 10:22:00.747 ERROR (MainThread) [asyncio] Task was destroyed but it is pending!
task: <Task pending name=‘Task-660’ coro=<Event.wait() done, defined at /usr/local/lib/python3.12/asyncio/locks.py:199> wait_for=>
2024-12-06 10:22:00.774 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_core_configurator application
2024-12-06 10:22:01.439 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-configurator with version 5.8.0
2024-12-06 10:22:10.958 WARNING (MainThread) [supervisor.jobs] ‘BackupManager.do_backup_partial’ blocked from execution, system is not running - startup
2024-12-06 10:22:31.076 WARNING (MainThread) [supervisor.jobs] ‘BackupManager.do_backup_partial’ blocked from execution, system is not running - startup
2024-12-06 10:22:31.569 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2024-12-06 10:22:31.570 INFO (MainThread) [supervisor.core] Supervisor is up and running
2024-12-06 10:22:31.570 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-12-06 10:22:31.572 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2024-12-06 10:22:31.578 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-12-06 10:22:31.578 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-12-06 10:22:31.579 ERROR (SyncWorker_2) [asyncio] Task was destroyed but it is pending!
task: <Task pending name=‘Task-722’ coro=<Event.wait() done, defined at /usr/local/lib/python3.12/asyncio/locks.py:199> wait_for=>
task: <Task pending name=‘Task-736’ coro=<Event.wait() done, defined at /usr/local/lib/python3.12/asyncio/locks.py:199> wait_for=>
Hello sjz26,
The file home-assistant.log.1 has the prior log file in it, but there is a bug that is being chased I heard about.
See if one of these fits and if so it should help guide you until there is a fix.
[5:30 AM]
[5:30 AM]
thank you sir goodenough! I will give them a read!
