Hi all,
I am sure there is something simple wrong with this YAML, but I can’t get it to work and I figure someone here will quickly correct me. I am trying to run an automation 1x/hour in the evening to switch on a space heater if the outdoor temperature is less than 55°. I can see the automation attempting to run at 5 minutes past the hour, but it stops because a condition fails. I assume this is because of my temperature condition syntax. YAML is below. Any help would be greatly appreciated!!!
alias: Turn On Space Heater Under 55 Degrees
description: ""
- platform: time_pattern
minutes: "5"
condition:
- condition: state
entity_id: weather.forecast_home
attribute: temperature
state: <55
- condition: time
before: "06:30:00"
after: "19:00:00"
weekday:
- sun
- mon
- tue
- wed
- thu
- fri
- sat
- type: turn_on
device_id: 925d31803a81253a2e498bdf8387880a
entity_id: switch.space_heater
domain: switch
mode: single
