I’m trying to create a template cover which calls scripts for the various actions which check if the windows are open before performing said actions.
I have this template cover:
cover:
covers:
dining_room_blind:
friendly_name: "Dining Room Blind"
set_cover_position:
service: script.dining_room_blind_set_cover_position_if_windows_closed
position: "{{ position }}"
set_cover_tilt_position:
service: script.dining_room_blind_set_cover_tilt_position_if_windows_closed
tilt_position: "{{ tilt_position }}"
position_template: "{{ state_attr('cover.blind_1', 'current_position') }}"
tilt_template: "{{ state_attr('cover.blind_1', 'current_tilt_position') }}"
icon_template: "{{ state_attr('cover.blind_1', 'icon') }}"
sending a cover.set_cover_position command from the UI and dev tools (call service) works fine.
however, sending cover.set_cover_tilt_position raises the following complaint:
Dining Room Blind: Error executing script. Invalid data for call_service at pos 1: expected int for dictionary value @ data[‘tilt_position’]
20:56:32 – (ERROR) helpers/script.py - message first occurred at 20:49:25 and shows up 3 timesDining Room Blind: Set cover tilt position if windows closed: If at step 1: Error executing script. Invalid data for call_service at pos 1: expected int for dictionary value @ data[‘tilt_position’]
20:56:32 – (ERROR) Scripts - message first occurred at 20:49:25 and shows up 6 times
What’s going on?
My Script looks like this:
alias: 'Dining Room Blind: Set cover tilt position if windows closed'
sequence:
- if:
// removed for brevity
then:
- service: cover.set_cover_tilt_position
data_template:
tilt_position: '{{tilt_position}}'
device_id: XXX
mode: restart
icon: mdi:blinds
Calling my script like this, works
tilt_position: 50
- How do I debug this for myself?
- whats actually going on, how do I make this work?
