I can’t figure out why this template isn’t working. If I go to services in Developer Tools, I am able to run ffmpeg.start with the entity_id, but this error seems to indicate that ffmpeg.start isn’t valid?
- alias: Wyzecam Noise Detection
platform: state
entity_id: input_boolean.wyzecam_noise_detect
data_template:
entity_id: binary_sensor.wyzecam_noise
service_template: >-
{% if (trigger.to_state) == 'on' %}
ffmpeg.start
{% elif (trigger.to_state) == 'off' %}
ffmpeg.stop
{% endif %}
2020-05-03 13:39:06 ERROR (MainThread) [homeassistant.components.automation] Wyzecam Noise Detection: Error executing script. Unexpected error for call_service at pos 1: Template rendered invalid service:
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 115, in async_prepare_call_from_config
domain_service = cv.service(domain_service)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 411, in service
raise vol.Invalid(f"Service {value} does not match format <domain>.<name>")
voluptuous.error.Invalid: Service does not match format <domain>.<name>
