Help with template helper sensor
Just need some help with trying to tweak a template helper sensor I created to track status of my HVAC system based on ecobee status. The code I have current and seems to work fine is:
{% set attributes = state_attr('climate.my_ecobee_4', 'equipment_running') %}
{% if 'heatPump2' in attributes %}
  Heat Pump Stage 2
{% elif 'heatPump' in attributes %}
  Heat Pump
{% elif 'auxHeat1' in attributes %}
  Furnace Stage 1
{% elif 'auxHeat2' in attributes %}
  Furnace Stage 2
{% elif 'compCool1' in attributes %}
  Cooling Stage 1
{% elif 'compCool2' in attributes %}
  Cooling Stage 2
{% elif 'fan' in attributes %}
  Fan
{% else %}
  Idle
{% endif %}
What I was to add to it is to track when the heat pump goes on defrost cycle. Based monitoring my supply air temperature using a sensor, I can see a dip in temperature while the unit is running on defrost and ecobee is still calling for heat and then after cycle completes the temperature rises again. How can I track the defrost by looking for this pattern and adding it the template sensor above. Below picture shows in red the temperature dips when defrost is running:
I was thinking tracking negative steep temperature drop trend followed by steep rise while ecobee status is heating (on heat pump) would be the way to identify when defrost cycle is running but I don’t know how to capture that in my template sensor. Any help with this would be really appreciated.
Set up a Trend binary sensor then add if/elif clauses that combine the two conditions as necessary:
{% set falling = is_state('binary_sensor.temp_falling', 'on') %}
{% if 'heatPump2' in attributes and falling %}
  Defrost - Heat Pump Stage 2
{% elif 'heatPump2' in attributes %}
  Heat Pump Stage 2
{% elif 'heatPump' in attributes and falling %}
  Defrost - Heat Pump
  Heat Pump
  Furnace Stage 1
  Furnace Stage 2
  Cooling Stage 1
  Cooling Stage 2
  Fan
{% else %}
  Idle
{% endif %}
Thanks for the code and hint regarding the template sensor. Trying to create a template sensor that captures the steep temperature drop followed by a quick rise within a 10 to 30 minute window of a defrost cycle but having a hard time with the parameters for it. Any advice on what parameters would be ideal for the template based on the graph above?
I think I figured out the trend parameters that seems to be working to relatively quickly indicate when defrost is running and off, thank you for the help with the script syntax, really appreciate it.
One last question but it’s less urgent, what do I need to add to the script to change icon based on the returned state?
I tried adding the following code in config yaml but got errors:
template:
- sensor:
  - name: HVAC Status
    state: >
        {% set falling = is_state('binary_sensor.hvac_supply_trend', 'on') %}
          Heat Pump Stage 2
          Defrost - Heat Pump
          Heat Pump
          Furnace Stage 1
          Furnace Stage 2
          Cooling
          Cooling Stage 2
          Fan
        {% else %}
          Idle
        {% endif %}
          icon: >
        {% if is_state('sensor.hvac_status', 'Defrost - Heat Pump') %}
        mdi:snowflake-melt
        {% elif is_state('sensor.hvac_status', 'Heat Pump')
        mdi:heat-pump-outline
        {% elif is_state('sensor.hvac_status', 'Furnace Stage 1')
        mdi:fire
        {% elif is_state('sensor.hvac_status', 'Furnace Stage 2')
        mdi:fire
        {% elif is_state('sensor.hvac_status', 'Cooling')
        mdi:air-conditioner
        {% elif is_state('sensor.hvac_status', 'Fan')
        mdi:fan
        {% else %}
        mdi:hvac-off
        {% endif %}
The error I get when I reload home assistant is:
Invalid config for ā€˜template’ at configuration.yaml, line 53: invalid template (TemplateSyntaxError: expected token ā€˜end of statement block’, got ā€˜mdi’) for dictionary value ā€˜sensor->0->state’, got "{% set attributes = state_attr(ā€˜climate.my_ecobee_4’, ā€˜equipment_running’) %}\n {% set falling = is_state(ā€˜binary_sensor.hvac_supply_trend’, ā€˜on’) %}\n {% if ā€˜heatPump2’ in attributes and falling %}\n Defrost - Heat Pump Stage 2\n {% elif ā€˜heatPump2’ in attributes %}\n Heat Pump Stage 2\n {% elif ā€˜heatPump’ in attributes and falling %}\n Defrost - Heat Pump\n {% elif ā€˜heatPump’ in attributes %}\n Heat Pump\n {% elif ā€˜auxHeat1’ in attributes %}\n Furnace Stage 1\n {% eli…
Incorrect indentation of the icon: option.
It should be vertically aligned with the state: option.
Please drop you last(next) question and mark Didgeri’s answer as Solution , this to keep question/solutions separate
You can Not use the ā€œiconā€ template like you do, partly it’s in the middle of nowhere
There are several solutions for this, and varies in syntax depended upon where
I fixed the indentation but still same issue:
template:
- sensor:
  - name: HVAC Status
    state: >
          Heat Pump Stage 2
          Defrost - Heat Pump
          Heat Pump
          Furnace Stage 1
          Furnace Stage 2
          Cooling
          Cooling Stage 2
          Fan
        {% else %}
          Idle
        {% endif %}
    icon: >
        mdi:snowflake-melt
        mdi:fire
        mdi:fire
        mdi:air-conditioner
        mdi:fan
        {% else %}
        Idle
        mdi:hvac-off
        {% endif %}
Invalid config for ā€˜template’ at configuration.yaml, line 75: invalid template (TemplateSyntaxError: expected token ā€˜end of statement block’, got ā€˜mdi’) for dictionary value ā€˜sensor->0->icon’, got ā€œ{% if is_state(ā€˜sensor.hvac_status’, ā€˜Defrost - Heat Pump’) %} mdi:snowflake-melt {% elif is_state(ā€˜sensor.hvac_status’, ā€˜Heat Pump’) mdi:heat-pump-outline {% elif is_state(ā€˜sensor.hvac_status’, ā€˜Furnace Stage 1’) mdi:fire {% elif is_state(ā€˜sensor.hvac_status’, ā€˜Furnace Stage 2’) mdi:fire {% elif is_state(ā€˜sensor.hvac_status’, ā€˜Cooling’) mdi:air-conditioner {% elif is_state(ā€˜sensor.hvac_status’, ā€˜Fan’) mdi:fan {% else %} mdi:hvac-off {% endif %}\nā€
For future reference, don’t mark a post with the Solution tag if you’re still getting errors trying to implement it.
The latest error is because the last icon value is invalid (remove Idle).
Try this, i won’t say it works, because i’ve never used it for a template-sensor, But in a card which supports template for the icon:element
Anyhow, the first row needs indented ( Look at your first Template ! )
haha, i never noticed the Idle ( But it should work regardless ) :slight_smile:
      icon: >-
        {% if is_state('sensor.moon_phase', 'new_moon')%} mdi:moon-new
        {% elif is_state('sensor.moon_phase', 'waxing_crescent')%}
        mdi:moon-waxing-crescent {% elif is_state('sensor.moon_phase',
        'first_quarter')%} mdi:moon-first-quarter {% elif
        is_state('sensor.moon_phase', 'waxing_gibbous')%}
        mdi:moon-waxing-gibbous {% elif is_state('sensor.moon_phase',
        'full_moon')%} mdi:moon-full {% elif
        is_state('sensor.moon_phase',  'waning_gibbous')%}
        mdi:moon-waning-gibbous {% elif is_state('sensor.moon_phase',
        'last_quarter')%} mdi:moon-last-quarter {% elif
        is_state('sensor.moon_phase', 'waning_crescent')%}
        mdi:moon-waning-crescent {% else %} away !!!  {% endif %}
And Please take a look at your ā€œlastā€ template ! , This is one other reason reason not to start NEW question in a Topic which are solved ! , we are filling the topic with bullocks
Well initial question was resolved so I had marked it as such based on your request above. I should have split the second question to another post. I appreciate your guidance, got it working with below:
template:
- sensor:
  - name: HVAC Status
    state: >
          Heat Pump Stage 2
          Defrost - Heat Pump
          Heat Pump
          Furnace Stage 1
          Furnace Stage 2
          Cooling
          Cooling Stage 2
          Fan
        {% else %}
          Idle
        {% endif %}
    icon: >-
        {% if is_state('sensor.hvac_status', 'Heat Pump')%} mdi:heat-pump-outline
        {% elif is_state('sensor.hvac_status', 'Defrost - Heat Pump')%} mdi:snowflake-melt
        {% elif is_state('sensor.hvac_status', 'Furnace Stage 1')%} mdi:fire
        {% elif is_state('sensor.hvac_status', 'Furnace Stage 2')%} mdi:fire-circle
        {% elif is_state('sensor.hvac_status', 'Cooling')%} mdi:air-conditioner
        {% elif is_state('sensor.hvac_status', 'Fan')%} mdi:fan
I’m new to the template helper. I’ve got one started but get an error message:
the code works in the Developer tab, so I’m not sure what mistake I’m making. Any help?
The mistake you made was identified in the red-tinted warning message displayed at the bottom of your screenshot.
You defined a Template Sensor that has a device class of power, a state class of measurement, and a unit of measurement of watts which means the sensor is expected to report a number. However, the template you created doesn’t report a number, it reports string values. The combination of measurement, power and watts makes no sense with Off, Standby, Running.
Remove the values you set for unit of measurement, device class and state class.
Thanks. I knew it was something like that. It’s now working.
