Help with template in action name
I have several scripts and automations to manage which garage doors open and close when someone arrives home, depending on whether the garage spots are empty, etc.
For cases where I want to ask the user which door he/she wants to open, I wrote this “ask which door to open” script that gets called from other scripts. I get a “template rendered invalid service” error. I narrowed it down to line 12 the template is somehow producing a blank result instead of the contents of the variable. If I replace the template with a hard-coded notification device, it works fine.
What am I doing wrong here? Thanks in advance!
alias: Which Door Do You Want to Open
fields:
  which_device:
    default: notify.mobile_app_iphone_de_marcos
sequence:
  - alias: Set up variables for the actions
    variables:
      action_left: "{{ 'LEFT_' ~ context.id }}"
      action_middle: "{{ 'MIDDLE_' ~ context.id }}"
      action_none: "{{ 'NONE_' ~ context.id }}"
  - alias: Ask which door to open
    action: "{{ which_device }}"
      message: Welcome home. Which garage door would you like to Open?
        actions:
          - action: "{{ action_left }}"
            title: Left
          - action: "{{ action_middle }}"
            title: Middle
          - action: "{{ action_none }}"
            title: None
  - alias: Wait for a response
    wait_for_trigger:
      - event_type: mobile_app_notification_action
        event_data:
        trigger: event
        event_data:
        trigger: event
        event_data:
        trigger: event
    continue_on_timeout: false
    timeout:
      hours: 0
      minutes: 5
      seconds: 0
      milliseconds: 0
  - alias: Perform the action
    choose:
      - conditions:
          - condition: template
            value_template: "{{ wait.trigger.event.data.action == action_left }}"
        sequence:
          - action: script.smart_garage_door_opener
              which_door: cover.left_door
              flash_lights: "no"
              what_to_do: open
              notification_type: none
              announcement_type: none
      - conditions:
            value_template: "{{ wait.trigger.event.data.action == action_middle }}"
        sequence:
              which_door: cover.middle_door
              flash_lights: "no"
              what_to_do: open
    default:
      - delay:
          hours: 0
          minutes: 0
          seconds: 1
          milliseconds: 0
description: ""
mode: parallel
I’m fairly sure the action field can’t accept templates.
I think you actually need to use a choose on the which_device and several notification actions
Are you relying on the default from the field to provide the value for the variable? Though that is intuitive, that’s not how it works. The default is just for the UI editor, the value is not passed when the script is called and the source doesn’t provide a value.
You can use the default() filter to get an actual default value:
    action: "{{ which_device | default('notify.mobile_app_iphone_de_marcos', true) }}"
        actions:
            title: Left
            title: Middle
            title: None
that was it! thank you.
