hi! I would like to use a template inside a script. The script turns on (and off) a hue lamp in the hallway. I’ve been reading this forum and tried to debug it myself with no luck. #1 works; the others don’t
alias: "Turn on hal_beneden and set timer"
sequence:
# Cancel ev. old timers
- service: script.turn_off
entity_id: script.timer_off1
- service: light.turn_on
entity_id: light.hal
#1 brightness: '200'
brightness: '{% if now().hour > 20 %}150{% elif now().hour < 8 %}150{% elif now().hour < 6 %}50{% else %}255{% e$
#3 brightness: >-
# {% if now().hour > 20 %}
# 150
# {% elif now().hour < 8 %}
# 150
# {% elif now().hour < 6 %}
# 50
# {% else %}
# 255
# {% endif %}
# Set new timer
- service: script.turn_on
Error with #1:
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/core.py", line 1130, in _safe_execute
await self._execute_service(handler, service_call)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 304, in wait
raise ValueError('Set of coroutines/Futures is empty.')
ValueError: Set of coroutines/Futures is empty.
Error with #3:
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/core.py", line 1143, in _execute_service
await handler.func(service_call)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/script.py", line 123, in service_handler
context=service.context)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/script.py", line 181, in async_turn_on
kwargs.get(ATTR_VARIABLES), context)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 131, in async_run
await self._handle_action(action, variables, context)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 210, in _handle_action
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 299, in _async_call_service
context=context
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 85, in async_call_from_config
domain, service_name, service_data, blocking=blocking, context=context)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/core.py", line 1101, in async_call
processed_data = handler.schema(service_data)
File "/srv/homeassistant/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 267, in __call__
return self._compiled([], data)
File "/srv/homeassistant/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 589, in validate_dict
return base_validate(path, iteritems(data), out)
File "/srv/homeassistant/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 427, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: expected int for dictionary value @ data['brightness']
Suggestions?
