It’s just a little weird that above shows it’s below horizon, but the state hasn’t yet updated… 4 minutes later, it does and changes to “below_horizon” … That is the root cause I believe.
Is it possible to check the attribute, if negetive=below, if positive=above?
Keep in mind, it doesn’t update on the second. It updates on the minute and when the attributes change. So there may be momentary times when it’s not 100% in sync because the sunrise/sets occur within the minute.
Also keep in mind that the sun sensor only has the current day’s sunset and sunrise and if you have past one of those points and not yet past midnight, then the calculations are made on the wrong times.
If you are close to equator, then this might not mean much, but if you instead are closer to one of the poles, then it can be some minutes off at peak times.
Edit: Looks like the builtin sun can actually do it here. Maybe it was just the automations that caused issues when the before sunrise and after sunset was used as a trigger. Well, I still stick to Sun2
You’re going to have the same issue you had with my first post… my second template fixes it. That’s the one you should be using as it will be the most accurate.
To be more clear with the warnings I posted, they will all have the caveats that are listed in this thread. It’s how templates work, it’s not the template that’s the problem.
Templates with now in them only update on the minute. Templates also only update when referenced entities update.
All templates posted here, yours, mine, etc will all have the same problems you see. The second template I posted will be the most accurate and will not require extra math when dst changes
I have another sensor that is looking at the “above_horizon” which works fine…
As soon as the “sun set time” hits, this sensor triggers (as it controls my lights automations)
But weirdly, when I want the above (which is a similar IF statement) - there’s a little lag before the sensor actually updates.
So at the minute of sunrise/set, this sensor updates instantly…
