robermf
(Roberto)
December 1, 2018, 10:06pm
1
Hello!
I am trying without success get the consumption data from Daikin AC.
With this link http://192.168.0.98/aircon/get_week_power I get this:
ret=OK,today_runtime=1376,datas=0/200/200/300/300/200/300
Where each number in datas the consumption of every day of the week (in 0,1 kWh values)
With this link ttp://192.168.0.98/aircon/get_day_power_ex?days=2 I get this:
ret=OK,curr_day_heat=3/2/1/3/1/2/2/2/4/3/4/3/3/3/4/4/3/2/2/3/2/3/2/0,prev_1day_heat=3/3/2/3/3/2/3/3/2/3/3/2/2/3/4/4/5/1/2/3/1/3/3/2,curr_day_cool=0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0,prev_1day_cool=0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0
" the power consumption (in 0.1 kWH) of the last 2 days, separated hour by hour starting from midnight and also separated for cooling and heating." Explanation from Github.
My question is: Is possible to make a sensor of daily consumption?
I made some test and it didnt work.
Thank you in advance.
VDRainer
December 1, 2018, 10:53pm
2
Copy and paste your return value in Dev tools/Templates and then you can experiment with it.
{% set value = 'ret=OK,today_runtime=1376,datas=0/200/200/300/300/200/300' %}
{{ value.split(',')[2].split('=')[1].split('/')[0] }}
This returns the first value of datas: 0
the second 200
, and so on.
Same for the second return value:
{% set value = 'ret=OK,curr_day_heat=3/2/1/3/1/2/2/2/4/3/4/3/3/3/4/4/3/2/2/3/2/3/2/0,prev_1day_heat=3/3/2/3/3/2/3/3/2/3/3/2/2/3/4/4/5/1/2/3/1/3/3/2,curr_day_cool=0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0,prev_1day_cool=0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0' %}
{{ value.split(',')[1].split('=')[1].split('/')[0] }}
Returns the first number of ‘curr_day_heat’
{{ value.split(',')[1].split('=')[1].split('/')[1] }}
the second.
Now you have something to play with.
EDIT: Here is some other explanation about splitting.
robermf
(Roberto)
December 1, 2018, 11:03pm
3
THANK YOU VERY MUCH!
I was totally lost. Now I can begin to play with something. Maybe now it will be possible to get
Best regards :)))
robermf
(Roberto)
December 2, 2018, 12:15am
4
I was making some tests before sleep and it works!
Again… Thank you very much! I was really lost Its good go to sleep after solve that.
- platform: rest
resource: http://192.168.0.98/aircon/get_day_power_ex
value_template: >
{{ ((float(value.split(',')[1].split('=')[1].split('/')[0])
+ float(value.split(',')[1].split('=')[1].split('/')[1])
+ float(value.split(',')[1].split('=')[1].split('/')[2])
+ float(value.split(',')[1].split('=')[1].split('/')[3])
+ float(value.split(',')[1].split('=')[1].split('/')[4])
+ float(value.split(',')[1].split('=')[1].split('/')[5])
+ float(value.split(',')[1].split('=')[1].split('/')[6])
+ float(value.split(',')[1].split('=')[1].split('/')[7])
+ float(value.split(',')[1].split('=')[1].split('/')[8])
+ float(value.split(',')[1].split('=')[1].split('/')[9])
+ float(value.split(',')[1].split('=')[1].split('/')[10])
+ float(value.split(',')[1].split('=')[1].split('/')[11])
+ float(value.split(',')[1].split('=')[1].split('/')[12])
+ float(value.split(',')[1].split('=')[1].split('/')[13])
+ float(value.split(',')[1].split('=')[1].split('/')[14])
+ float(value.split(',')[1].split('=')[1].split('/')[15])
+ float(value.split(',')[1].split('=')[1].split('/')[16])
+ float(value.split(',')[1].split('=')[1].split('/')[17])
+ float(value.split(',')[1].split('=')[1].split('/')[18])
+ float(value.split(',')[1].split('=')[1].split('/')[19])
+ float(value.split(',')[1].split('=')[1].split('/')[20])
+ float(value.split(',')[1].split('=')[1].split('/')[21])
+ float(value.split(',')[1].split('=')[1].split('/')[22])
+ float(value.split(',')[1].split('=')[1].split('/')[23])) ) /10 | float }}
unit_of_measurement: "kWh"
fredrike
(Fredrik Erlandsson)
February 19, 2019, 10:51am
5
Ouch, that is quite ugly. Why not aggregate with sum
So your value_template
becomes:
{{ value.split(',')[1].split('=')[1].split('/')|map('float')|sum/10 }}
And this is the value_template
for cool:
{{ value.split(',')[3].split('=')[1].split('/')|map('float')|sum/10 }}
robermf
(Roberto)
February 21, 2019, 11:48am
6
Thank you very much for your answer.
Yes, it looks nicer. I will try
Definitely I have to learn about template!
Or a bit hardened version :
value_template
for cool:
{{ value.split('curr_day_cool=')[1].split(',')[0].split('/') | map('float') | sum() / 10 }}
value_template
for heat:
{{ value.split('curr_day_heat=')[1].split(',')[0].split('/') | map('float') | sum() / 10 }}
fredrike
May 17, 2020, 5:54am
8
Nice one!
This is going to be replaced with real support in 0.111 though.
dixkom
(dixkom)
January 28, 2021, 8:55am
9
is it already supported by plugin or do I have to create custom sensor to track consumption?
Is there a plan to deliver the consumption in a total increasing entity, so this can be integrated in the energy model from HA directly?
