Hi I am battling to get ESPhome to switch off this template switch once it has run.
This is for a fish tank water change system, the system has a variety of switches and sensors to control the operation.
My issue is in setting up a template switch which only runs under certain conditions and all is running well except for the fact that the moment I execute the switch to carry out the water change it does not switch off in HA and remains ‘on’. This is irrespective of whether the conditions are met for the water change or not. I have done a fair amount of searching and have tried to change the optimistic setting but then need to switch the switch off manually and I have not been successful in writing this code (im not great at coding).
As the esp is rebooted the state in HA is shown as Off, the moment I activate it it sets to ON and remains ON when it should obviously be set to off once complete.
Any help would be greatly appreciated
The main area of the code is here
optimistic: True
icon: mdi:water-sync
on_turn_on:
if:
condition:
all:
- switch.is_off: pump_in
- switch.is_off: pump_out
- lambda: |-
return id(leak_sensor).state < 0.14;
then:
- logger.log: "Water Change - Pumping Out"
- switch.turn_off: filter
- switch.turn_off: heater
- switch.turn_on: pump_out
- delay: !lambda "return (id(pump_out_time).state) * 10000 ;"
- switch.turn_off: pump_out
- switch.turn_on: pump_in
- logger.log: "Water Change - Pumping In"
- delay: !lambda "return (id(pump_in_time).state) * 10000 ;"
- switch.turn_off: pump_in
- switch.turn_on: filter
- switch.turn_on: heater
- logger.log: "Water Change Complete"
else:
- switch.turn_off: water_change
