Currently, when displaying a person.xxxxx entity in a card, it will show, “Home”, “Work”, “Away” in the card. I would like to change that behavior so instead of displaying “Away”, to display a device_tracker geolocation address instead. Below is my best attempt at doing this by creating a new entity, marcos_person, instead of using person.xxxxx. However, I’m getting the error below when starting up Home Assistant:
2020-05-11 14:01:05 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] while scanning for the next token
found character '%' that cannot start any token
in "/config/configuration.yaml", line 37, column 10
2020-05-11 14:01:05 ERROR (MainThread) [homeassistant.bootstrap] Failed to parse configuration.yaml: while scanning for the next token
in "/config/configuration.yaml", line 37, column 10. Activating safe mode
Below, is what I have in my configuration.yaml
sensors:
marcos_person:
value_template: >-
{% if is_state('person.marcos_smith', 'Away') %}
sensor.sm_a505u_geocoded_location.state
{% endif %}
