Hey guys
I’m getting tired of copy pasting code, so i thought it was time to jump into templating. Now that have read the site documentation, i think i still need a kick start from one of you to make it happen
So here’s what i have and what i’m trying to achieve
I added the hdm_cec component and defined the devices that have been detected in my configuration.yaml file as below
hdmi_cec:
devices:
1:
1: Kodi
2: Videotron
3: Blueray
I then tested it out with the service call within HA by settings using the following
Domain hdmi_cec Service power_on Service Data ( JSON, optional) { "device": "Blueray" }
That worked perfectly
Then i built an input select section to be able to trigger each of the devices from a drop down
input_select:
tvsource:
name: Television source select
options:
- Kodi
- Videotron
- Blueray
- None
initial: None
For which i added some automations in the automation.yaml file , which works as well
- alias: Switch TV input1
platform: state
entity_id: input_select.tvsource
to: "Videotron"
service: hdmi_cec.select_device
data: { "device": "Videotron" }
- alias: Switch TV input2
platform: state
to: "Blueray"
data: { "device": "Blueray" }
- alias: Switch TV input3
platform: state
to: "Kodi"
data: { "device": "Kodi" }
But although it’s working, it’s causing a lot of code duplication that i would like to avoid.
If one can help me out and send me in the right direction with a working example based on my config , i think i should be good to start from there for my future needs.
Thanks in advance guys
