Help with templates and automations
Hey guys,
I’m trying to control the heater (turn on and off) if the temperature is below 18C or above 22C and if someone is at home.
Any help? Thank you
#Climate
- action:
  - data:
    service_template: >
      {% if is_state('sensor.ulisses', 'home') or is_state('sensor.daniela', 'home') %}
        {% if states('sensor.pws_temp_c' | float) < 18 %}
      - turn_on:
        service: switch.turn_on
          entity_id: switch.heater_switch
        {% elif states('sensor.pws_temp_c' | float) > 22 %}
      - turn_off:
        service: switch.turn_off
        {% else %}
      - turn_on:
        {% endif %}
      {% else %}
      - turn_off:
      {% endif %}
  alias: 'Climate'
  - above: '22'
    entity_id: sensor.pws_temp_c
    platform: numeric_state
  - below: '18'
Why not use the generic thermostat component if your heater is a switch and a temp-sensor:
climate:
  - platform: generic_thermostat
    heater: switch.heater_switch
    target_sensor: sensor.pws_temp_c
    min_temp: 18
    max_temp:22
And then set climate.room to “heat” when someone is home?
Thank you @vegard!
