Help with templating binary sensors
I have created a reasonably complicated binary sensor entity for a PWM dimmer
I now want to create 8 of these attached to different LEDC PWM output channels
Obviously I don’t want to copy/ maintain 8 copies of the code
It sounds like templating should enable me to do this but I am struggling to find worked examples of using templating to create multiple entities like I want to do
Clearly I am looking in the wrong places…
Templates are a completely different thing really, a template binary switch is just one that can include code to determine the state.
You probably need to read about substitutions, packages etc - although I am not sure if that will achieve what you want:
Thank-you!
Funnily enough, I woke today with a different search query in my head that found the same Configuration Types article. “Packages as Templates” works perfectly
I logged in to post this solution but found your post :slight_smile:
  dimmer_1: !include
    file: packages/dimmer.yaml
    vars:
      switch_no: 1
      switch_pin_no: 5
      pwm_pin_no: 6
Thanks again
