I’m just getting used to templates.
I have already understood some of the basics.
Since the new update it is possible to use a selection field for the effects for WLED.
Can someone explain how to use this?
# Example select entity that extracts effects from a light.
# When you change the selected option, the effect of the light changes.
template:
select:
- name: "Example select: WLED effect"
state: "{{ state_attr('light.wled', 'effect') }}"
options: "{{ state_attr('light.wled', 'effect_list') }}"
select_option:
service: light.turn_on
entity_id: light.wled
effect: "{{ option }}"
How can I use this template to get a selection field in the frontend?
Thx for help.
Regards
Herbert
pedolsky
(Pedolsky)
2
Copy it into your configuration.yaml or - if you use it - your packages
directory.
Hi thanks.
I have already copy it to my template.yaml
Wasserverbrauch:
unit_of_measurement: "Kubikmeter"
value_template: {{ (states('sensor.wasserzaehler') | float - 400) | round(2) }}
select:
state: "{{ state_attr('light.budenbeleuchtung', 'effect') }}"
options: "{{ state_attr('light.budenbeleuchtung', 'effect_list') }}"
select_option:
entity_id: light.budenbeleuchtung
But how can i access this WLED Effect on my FrontEnd?
The other Sensor i can access in HA.
pedolsky
(Pedolsky)
4
Simply add a new card with your new entity.
neue Karte hinzufügen —> Karte auswählen nach Entität —> in das Suchfeld eingeben: WLED —> Kästchen links anklicken —> unten rechts weiter klicken —> Auswahl treffen
tom_l
5
Are you aware you can select the effect without creating the template sensor?
It is available at the bottom of the WELD light more-info pop up when the light is on:
Shame on me ![:roll_eyes: :roll_eyes:](https://community.home-assistant.io/images/emoji/twitter/roll_eyes.png?v=9)
I must have commented out the template config file while testing a few things. That’s why I couldn’t find the template.
Now i have found it.
Thanks ![:wink: :wink:](https://community.home-assistant.io/images/emoji/twitter/wink.png?v=9)
Regards
Herbert
yes, i know that. But on my mobile this field is very tiny and i can’t scroll it.
tom_l
8
Fair enough. Just checking.
